PBP 2.60 upgrade and 18F4550
Results 1 to 11 of 11
    Jul 2009
    Ohio, USA
    Default PBP 2.60 upgrade and 18F4550
    I just got the upgrade 2.60 and found the "AllDigital.pbp" include on another thread...works great!
    I still am concerned about an error I get
    Error[113] c:\pbp\18f4550.inc 21 : Symbol not previously defined (_FCMEN_OFF_1H)
    Here is a simple code
    ' Example program to blink an LED connected to PORTB.0 about
    ' once a second
        INCLUDE "modedefs.bas"
        include "ALLDIGITAL.pbp"
        OSCCON =$60'72 'clock speed
    LED    VAR  PORTB.0   ' Assign name "LED" to PORTB.0
    mainloop:
       High LED        ' Turn on LED connected to PORTB.0
       Pause 500       ' Delay for .5 seconds
       Low LED         ' Turn off LED connected to PORTB.0
       Goto mainloop   ' Go back to loop and blink LED forever
    I can not reproduce your error here. My guess is when you changed the *.inc to use the internal OSC something else got changed?
    Post the configs .
    Several years ago, Microchip had erroneously called that bit _FCMEM_OFF_1H.
    I think mister-e pointed it out to me.
    You could ...
    1. Rename your config bit to that.
      The bit is in your c:\pbp\18F4550.INC file
    2. Correct the misspelled bit in Microchip's c:\program files\microchip\mpasm suite\P18F4550.inc file.
    3. Update MPLAB and it should go away.
      http://www.microchip.com/stellent/id...&part=SW007002
    If someone has a PBP version prior to 2.60 ...
    Use this one instead ... (MPLAB V8.15a)
    http://melabs.com/support/mplab_old_versions.htm
    Jul 2009
    Ohio, USA
    You could ...
    Ok...But rename it _FCMEM_OFF_1H. with an M or N?
    Jul 2009
    Ohio, USA
    Post the configs .
    ;*  18F4550.INC                                                 *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2009 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 03/20/09                                        *
    ;*  Version   : 2.60                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
            LIST p = 18F4550, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "P18F4550.INC"	; MPASM  Header
            __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
            __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
            __CONFIG    _CONFIG2L, _PWRT_OFF_2L & _BOR_ON_2L & _BORV_3_2L & _VREGEN_ON_2L
            __CONFIG    _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
            __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L
            NOLIST
            LIST
    EEPROM_START	EQU	0F00000h
    BLOCK_SIZE	EQU	32
    Jul 2009
    Ohio, USA
    Ok I changed them all to _FCMEN.
    Now my led does not blink anymore...but the error is gone!
    Quote Originally Posted by Mike2545 View Post
    That is what you had ??
    You code appears that you want to use the internal OSC but the configs show an external.
    Try this
    _FOSC_INTOSC_HS_1H
    in place of
    _FOSC_HSPLL_HS_1H
    You can go to the MPASM Suite in program files\microchip, look at the *.inc file there to see all of the config options. Do not modify that file.
    Jul 2009
    Ohio, USA
    Try this
    _FOSC_INTOSC_HS_1H
    in place of
    _FOSC_HSPLL_HS_1H
    Thank a bunch...I changed the MPASM file back to FCMEM and made the PBP .INC to match, also set it to the internal OSC as you showed.
