Sinewaves using interrupts.
Results 1 to 26 of 26
    Bombay, India
    Hi Hank
    If you're planning to use the digitally synthesised sine wave for audio purposes, please re-consider the number of samples. 16 samples are good enough to generate a sine wave for the CRO, but for the ear,.... well, it's a different game altogether.
    I had used the DDS technique, albeit with a PSOC, to generate pure tones (sinewaves of fixed frequency) for a clinical audiometer. You will get a clean sine wave on the scope, but, the distortion present in the wave will make it unsuitable for any audio purist. So, I had to switch over to the AD9832 which should be quite similar in function to the 9835(I haven't checked)
    The AD9832 is a 1024 point sampled wave DDS IC. The results I obtained from this are just excellent. Before this, I had used a ML2036 which is now obsolete.
    You might achieve the tones, but, you may not like the sound you get using a 16 point DDS. Let me not discourage your collaborative effort, but look at it as a gentle helmet I've gifted you to save the remaining hair on your head LoL
    Cheers
    Mar 2009
    Hi Jerson,
    Weirdly the AD9835 is available much cheaper on Ebay than the AD9832 - http://cgi.ebay.com.sg/AD9835BRU-Com...item35ac588755 )
    Ok, I'll give part of it a go:
    For a 5K signal with 32 samples, thats 32 x 5000 = 160,000/sec times to hit the interupt. With no real numbers to use here, lets say it takes 100 instructions to "hit" the int. So thats 1,600,000 ins/sec or 1.6mips. so to start off, i would think at a min 8 meg clock (2mips)
    And what about generating such to two decimal places (eg 4999.22Hz) - what impact does that have on the number (100x more?)
    Actually my intentions aren't particularly music driven, but while on that vein, here's someone pushing the PIC DDS (ADSR) envelope...
    I actually totally agree about the moderation (a big high five from me)...it was just a bit of tongue in cheek - I too normally forget to answer the question (& for a good while, whenever I got presented with the coffee question I always got the answer wrong - I was just putting in the missing letter as the answer .....a case of RTFQ Hank!)
    Aug 2005
    Michigan, USA
    I agree that if you're doin' audio you should look at one of the many DDS chips from Analog Devices. They used to be very nice about samples too, which I took advantage of when building a DDS Ham Radio project a few years ago.
    Regards, Mike
