Sinewaves using interrupts.
Results 1 to 26 of 26
    Bombay, India
    I want to get clear about something interupt related here. If I have a pure ASM isr, does that mean I don't have to worry about PBP stuff at all when I enter and exit? So for instance, if I set PIE for timer 1 and GIE, I know my interupt will fire any time. I also know the PIC will tend to W,STATUS, and PCLATH, (more or less depending on device). So I don't need to worry about anything else? And if I address a user defined variable in my ISR, I do that with _VariableName? If its that easy, thats wonderful.
    I can answer that for you. The ISR only needs to save as many registers as you are going to use in the ISR. So, if you plan on using W, Status, FSR, and any other registers that are used in the main program code, you need to save them on entry to the ISR and restore them while getting out. The moment you mix in PBP in an ASM ISR, you need to worry about the variables that PBP starts using.
    PBP uses a lot of internal variables called T1, T2, R0, R1, etc
    The moment you start using PBP math, logical and, if x and y then type constructs, these variables are used. So, you are better off not using PBP inside interrupts if you mark the ISR as ASM code with DT_ints The best way is to look at the generated LST file for the ISR code; you will learn a lot by just inspecting it.
    A simple x = y type assignment does not need any PBP variables and it will most certainly work in ASM.
    Mar 2009
    Default Re: Sinewaves using interrupts.
    Ok, old thread of mine & hands up...short of dabbling with scalerobotics cool sinewave generation program I never actually progressed much further - but I keep coming back to this DDS issue....I reckon I can do so much cool stuff once I've mastered the art of generating sine waves under my control
    Now I'm never the brightest button in the sewing box, but I do have dogged determination (rough translation "a pest")...I'll often kludge my way through without necessary understanding every part of the process - So with this in mind, I hope to start soon again on this pesky DDS melarky.
    So some questions.....
    all this talk of a 24 bit accumulator - how do I achieve that on a 12LF1822 with PICbasic?!!!
    Would up to 4.8Khz be do-able in HPWM for the DAC aspect?
    Can I really expect to get granular with setting the frequency without recourse to floating point? (I want to be able to set the frequency via another PIC by fiielding an Eusart interrupt to the DDS PIC)
    There are those on the net, that have done this with other processors. The Atmel AT90S2313 seems to figure large due to the lower number of clock cycles it takes per instruction. This chap has posted a great webpage...
    http://www.myplace.nu/avr/minidds/index.htm
    Including code....
    http://www.myplace.nu/avr/minidds/minidds.asm
    for those that have a clue (rules me out), how much of an ordeal would it be to move that over to a PIC?
    Is this a project where I really ought to start learning assembly?
    Hi Hank,
    Note that the avr project needs at least 8 I/O pins to drive the resistor ladder(DAC). So with a PIC12f series you are stuck using PWM, serial DAC or a dedicated DDS chip.
    I tried a spi DAC, too slow. Couldn't get over 600hz. It wouldn't be too hard to do the avr dds with a pic. Use a look up table and a loop and write each value to an 8bit port. Not sure how the speed would compare with an AVR?
    This is the best, but it is expensive
    http://www.sparkfun.com/products/9169
    I wrote some code for this in PBP if you are interested.
    cheers
    Mar 2009
    Hi Mark,
    Agreed about the 12lf1822's 6 Inputs & 5 outputs being insufficient for a resistor ladder ...I therefore have three options...
    1. Use HPWM
    2. Use the 12lf1822's internal 5 bit DAC (which while woeful, is handy from a low parts count & convenience/learning perspective)
    3. Go with a larger 14 pin sibling (eg 16lf1824) & use a reistor ladder.
    As much as I'd really like to just use the dedicated DDS chips, but they're way overkill for my modest needs, too expensive & also I'd like to lean how to roll my own so to speak.
    Just sounding the ground again here.
