Hi Henrik,
That all makes sense....I guess I could slowly add stuff into the interrupt handler & check the scope interrupt frequency (vs Mr E's calculator), I should then be able to account for the overhead of adding each bit in ...and then build the compensation back into the code.
I'd like to be able to generate the sine wave with a little more accuracy becuase an error of 10% is a little too much.
