Confused.... Help Please!
Results 1 to 32 of 32
    Aug 2010
    Maryland, USA
    How do you send a space to the LCD? In fact, How do you send any character to the LCD? keep in mind, I don't think the number 3 is the same as "3". The number 3 is an interger, and "3" is a string. I assume the string is really converted to its UNICODE equal. So I THINK (i am not sure) these would be 2 different arrays:
    t(0)=1
    t(1)=3
    t(2)=9
    t(0)="1"
    t(1)="3"
    t(2)="9"
    the problem you are facing, is there is NO integer space. there are only numbers 0-infinety. BTW there is also no n. the target after 9. So it should be as big a problem as the space if you are using an array of intergers.
    If you use an array of strings, each element is only 1 charater big, the space is no problem. It sounds to me like you are trying to mix numbers and strings. That is a big NO-NO!
    If you can post some or all of your code, I may understand better. I have no inclination to write it for you (and I don't think you want me to), but I find I am having trouble figuring out how to make sense to you.
    maybe just post the array and the LCD update part. Or get the LCD part number from your dad so I can look at the data sheet and understand how to talk to it. Or better yet, attach the datasheet here.
    -Bert
    Sep 2010
    t(0)=1
    t(1)=3
    t(2)=9
    t(0)="1"
    t(1)="3"
    t(2)="9"
    You are correct, the code used to fill the array (for testing purposes) is the following
      FOR I = 0 TO 29
      RANDOM RAND
      B0 = RAND // 10 ' Gives me numbers 0-9
      NOS[I] = B0
      NEXT
    And the LCD...
     CMCON = 7
     DEFINE OSC 20                               '20MHZ XTAL
     DEFINE LCD_DREG PORTB                      'PORT B LOW 4 BITS
     DEFINE LCD_DBIT 0                          'DATA BITS 0-3
     DEFINE LCD_RSREG PORTA                     'RS REG PORTA
     DEFINE LCD_RSBIT 4                         'RS BIT 4 PORT A
     DEFINE LCD_LINES 4                         '4 LIN LCD SET
     DEFINE LCD_EREG PORTB                      'EREG (ENABLE)
     DEFINE LCD_EBIT 4                          'PORTB BIT 4
     DEFINE LCD_BITS 4                          'LCD IN 4 BIT MODE
     PAUSE 1000                                 'INITIALIZE LCD
    how can I generate a random number as a string? as that would as you say save me alot of problems... as far as the manual goes PBP has limited support for strings, is there a ToString equivalent for PBP?
    To write to the lcd I simply use LCDOUT found on the pbp manual but at the moment since the randomly generated numbers are int's i can only go 0-infinity as you say.
    I need a way to generate random numbers as string values since spaces gave a Unicode value of 3 again as you stated.
    As for shifting the values within the array I cannot find any functions specifically for this in the manual so I will just have to resort to using a for next loop to shift the values around.
    Not what you want but you could use a LOOKUP table after the random number is generated.
    Aug 2010
    Maryland, USA
    Thanks Dave, Glad someone is watching "me". I am always worried I will misguide him, and no one will be watching.
    Anyway, Go back and look at post 7 I think. Now that you and I both understand you will be using strings, (I assumed this the whole time, my bad), it may make more sense to you. The first part shows the quickest way I know of to shift the array. And at the same time check for losing. in my example, only t(0)-t(4) are displayed. t(5) is the you lose check.
    The second part shows 1 way to check for a hit, then adjust the array.
    I agree with Dave, use a lookup to match a number with a string.
    -Bert
    Sep 2010
    Ahhh good point, I didnt think of that! and I have them in another file =)
    Sep 2010
    Hey guys, thanks for the support before...
    I was indeed heading down the wrong path with my approaches in the end I just put the Ascii equivilents of the numbers 0-9 and "n" into the array instead of trying to tell the LCD to display the Decimal values...
    MUCH EASIER
    Timing is a bit of a pain, since the main loop counts and GoSub's to other areas (this adds about half a second to the count sometimes) but I'm working on that.
    Guess my main problem is my habit of keep looking at "visual" syntax as a reference, since everything appears to run simultaniously... where as on this its loops in loops all the time hehe.
    EDIT: Now that I have that sorted, once the code is working and bugs ironed out I will rename the variables to something that makes sense to others reading it and upload the source with the hardware layout for those interested.
    COOL!!!
    I am looking forward to seeing/playing it. could use a little fun!
    Sep 2010
    I seem to have hit a bit of a problem, when I compile the code everything is fine it shows 0 errors 0 warnings but 2 suppressed (cant seem to get any output on these).
    However when I go to program the PIC with the compiled code it just loops forever on programming and will not actually write to the PIC.
    I have checked all settings including con bits all is fine, I had an issue like this before when i placed a return in the code without anything to return to but that is no longer the case... I am stuck
    EDIT: Nevermind power ran out on the pack powering the board
