Confused.... Help Please!
Results 1 to 32 of 32
    Sep 2010
    I think you are following me now. the LCD is really static, not scrolling, the array is what scrolls. Yes, as I posted in the beginning, start with the array filled with blank spaces or " " if you will.
    try it out at first with just adding a number to the array every second, then updating the LCD. it should have the scroll effect you are looking for. The number you add to the array should be a random number, I don't recall if PBP has a random number generator, but you could just increment the number for now.
    Once you have that worked out, move on to making the aim change as you press the aim button. from there its all just logic and playing with the array.
    Indeed, I continue to underestimate the speed of 20Mhz.
    I will be able to use the array manipulation as you say in a for next loop easily
    I think i will first start with the shooting the far left number only for now and then move onto numbers anywhere later on since that will require that I scn the array and adjust it many times.
    I do have the number changing figured out and also the "n" character and I can also shoot thats no problem ... I have the debounce and all that sorted it was just the scrolling i wasnt sure about since I was thinking of another approach.
    Unfortunately since pbp does not support that approach directly its alot easier to just as you say manipulate the array, I will get on with programming it tomorrow.
    Aug 2010
    Maryland, USA
    That's great! Will you be sharing? Just curious cuz I like this application. As someone who played this when it was new, it just seems cool to have.
    Are you willing to share your LCD hookup? And your actual part number for it? I would like to play with LCD's, but never seem to find time to hunt one down. No worries if you don't want to, you ARE NOT obligated to in any way.
    I have had fun helping with this, you are required to share a pic or video though.
    -Bert
    Sep 2010
    Of course!
    I will be happy to share any information with you regarding the board and my dad can provide you with the part numbers and all.
    I have just gone back over the notes for this program before I began writing it and I have noticed that the array is made up of "Bytes" meaning I cannot enter a space or " " since it sees it as a string or char and converts it to the decimal value any ideas?
    I suppose I could just get the decimal value and check to see if the vallue in the array is equal to that value and just override it for the lcd printing a space, it is just awquard to do it that way and means more code hehe
    Aug 2010
    Maryland, USA
    Quote Originally Posted by UKIkarus View Post
    Always keep this in mind, everything is made up of bytes, strings and things are just converted for our convinence to read. So you are correct, the " " IS repersented by some number, that is the number to check against.
    But I would have thought using PBP, you could have a statement like t(2)=" ". that should be no different then t(3)="3".Of course this is different then T(3)=3 with no quotes. Am I wrong? good chance of that, but either way assuming I am not wrong, will work just fine.t(2)=" " means PBP will convert " " to some byte. then your check would be IF T(2) = " ". the key here may be in the quotes.
    -Bert
    Sep 2010
    The issue is that a space is equal to the decimal value of 3 as you stated above, since the decimal numbers 0-9 are being used already it will remove any cells filled with 3 if i were to check that.
    When an array is created and all the cells are empty they are literally empty right? filled with nothing? is there a way to empty a cell or delete its contents? I cannot seem to find any information on array manipulation in the manual (im guessing its old)
    This includes shifting values in cells too, all i can find is a section about creating the array.
    It does have ArrayRead and ArrayWrite but those are for strings.
    Aug 2010
    Maryland, USA
    How do you send a space to the LCD? In fact, How do you send any character to the LCD? keep in mind, I don't think the number 3 is the same as "3". The number 3 is an interger, and "3" is a string. I assume the string is really converted to its UNICODE equal. So I THINK (i am not sure) these would be 2 different arrays:
    t(0)=1
    t(1)=3
    t(2)=9
    t(0)="1"
    t(1)="3"
    t(2)="9"
    the problem you are facing, is there is NO integer space. there are only numbers 0-infinety. BTW there is also no n. the target after 9. So it should be as big a problem as the space if you are using an array of intergers.
    If you use an array of strings, each element is only 1 charater big, the space is no problem. It sounds to me like you are trying to mix numbers and strings. That is a big NO-NO!
    If you can post some or all of your code, I may understand better. I have no inclination to write it for you (and I don't think you want me to), but I find I am having trouble figuring out how to make sense to you.
    maybe just post the array and the LCD update part. Or get the LCD part number from your dad so I can look at the data sheet and understand how to talk to it. Or better yet, attach the datasheet here.
    -Bert
    Sep 2010
    t(0)=1
    t(1)=3
    t(2)=9
    t(0)="1"
    t(1)="3"
    t(2)="9"
    You are correct, the code used to fill the array (for testing purposes) is the following
      FOR I = 0 TO 29
      RANDOM RAND
      B0 = RAND // 10 ' Gives me numbers 0-9
      NOS[I] = B0
      NEXT
    And the LCD...
     CMCON = 7
     DEFINE OSC 20                               '20MHZ XTAL
     DEFINE LCD_DREG PORTB                      'PORT B LOW 4 BITS
     DEFINE LCD_DBIT 0                          'DATA BITS 0-3
     DEFINE LCD_RSREG PORTA                     'RS REG PORTA
     DEFINE LCD_RSBIT 4                         'RS BIT 4 PORT A
     DEFINE LCD_LINES 4                         '4 LIN LCD SET
     DEFINE LCD_EREG PORTB                      'EREG (ENABLE)
     DEFINE LCD_EBIT 4                          'PORTB BIT 4
     DEFINE LCD_BITS 4                          'LCD IN 4 BIT MODE
     PAUSE 1000                                 'INITIALIZE LCD
    how can I generate a random number as a string? as that would as you say save me alot of problems... as far as the manual goes PBP has limited support for strings, is there a ToString equivalent for PBP?
    To write to the lcd I simply use LCDOUT found on the pbp manual but at the moment since the randomly generated numbers are int's i can only go 0-infinity as you say.
    I need a way to generate random numbers as string values since spaces gave a Unicode value of 3 again as you stated.
    As for shifting the values within the array I cannot find any functions specifically for this in the manual so I will just have to resort to using a for next loop to shift the values around.
