Confused.... Help Please!
Results 1 to 32 of 32
    Sep 2010
    How do you send a space to the LCD? In fact, How do you send any character to the LCD? keep in mind, I don't think the number 3 is the same as "3". The number 3 is an interger, and "3" is a string. I assume the string is really converted to its UNICODE equal. So I THINK (i am not sure) these would be 2 different arrays:
    t(0)=1
    t(1)=3
    t(2)=9
    t(0)="1"
    t(1)="3"
    t(2)="9"
    the problem you are facing, is there is NO integer space. there are only numbers 0-infinety. BTW there is also no n. the target after 9. So it should be as big a problem as the space if you are using an array of intergers.
    If you use an array of strings, each element is only 1 charater big, the space is no problem. It sounds to me like you are trying to mix numbers and strings. That is a big NO-NO!
    If you can post some or all of your code, I may understand better. I have no inclination to write it for you (and I don't think you want me to), but I find I am having trouble figuring out how to make sense to you.
    maybe just post the array and the LCD update part. Or get the LCD part number from your dad so I can look at the data sheet and understand how to talk to it. Or better yet, attach the datasheet here.
    You are correct, the code used to fill the array (for testing purposes) is the following
      FOR I = 0 TO 29
      RANDOM RAND
      B0 = RAND // 10 ' Gives me numbers 0-9
      NOS[I] = B0
      NEXT
    And the LCD...
     CMCON = 7
     DEFINE OSC 20                               '20MHZ XTAL
     DEFINE LCD_DREG PORTB                      'PORT B LOW 4 BITS
     DEFINE LCD_DBIT 0                          'DATA BITS 0-3
     DEFINE LCD_RSREG PORTA                     'RS REG PORTA
     DEFINE LCD_RSBIT 4                         'RS BIT 4 PORT A
     DEFINE LCD_LINES 4                         '4 LIN LCD SET
     DEFINE LCD_EREG PORTB                      'EREG (ENABLE)
     DEFINE LCD_EBIT 4                          'PORTB BIT 4
     DEFINE LCD_BITS 4                          'LCD IN 4 BIT MODE
     PAUSE 1000                                 'INITIALIZE LCD
    how can I generate a random number as a string? as that would as you say save me alot of problems... as far as the manual goes PBP has limited support for strings, is there a ToString equivalent for PBP?
    To write to the lcd I simply use LCDOUT found on the pbp manual but at the moment since the randomly generated numbers are int's i can only go 0-infinity as you say.
    I need a way to generate random numbers as string values since spaces gave a Unicode value of 3 again as you stated.
    As for shifting the values within the array I cannot find any functions specifically for this in the manual so I will just have to resort to using a for next loop to shift the values around.
    Not what you want but you could use a LOOKUP table after the random number is generated.
    Aug 2010
    Maryland, USA
    Thanks Dave, Glad someone is watching "me". I am always worried I will misguide him, and no one will be watching.
    Anyway, Go back and look at post 7 I think. Now that you and I both understand you will be using strings, (I assumed this the whole time, my bad), it may make more sense to you. The first part shows the quickest way I know of to shift the array. And at the same time check for losing. in my example, only t(0)-t(4) are displayed. t(5) is the you lose check.
    The second part shows 1 way to check for a hit, then adjust the array.
    I agree with Dave, use a lookup to match a number with a string.
    -Bert
    Sep 2010
    Ahhh good point, I didnt think of that! and I have them in another file =)
    Sep 2010
    Hey guys, thanks for the support before...
    I was indeed heading down the wrong path with my approaches in the end I just put the Ascii equivilents of the numbers 0-9 and "n" into the array instead of trying to tell the LCD to display the Decimal values...
    MUCH EASIER
    Timing is a bit of a pain, since the main loop counts and GoSub's to other areas (this adds about half a second to the count sometimes) but I'm working on that.
    Guess my main problem is my habit of keep looking at "visual" syntax as a reference, since everything appears to run simultaniously... where as on this its loops in loops all the time hehe.
    EDIT: Now that I have that sorted, once the code is working and bugs ironed out I will rename the variables to something that makes sense to others reading it and upload the source with the hardware layout for those interested.
    COOL!!!
    I am looking forward to seeing/playing it. could use a little fun!
    Sep 2010
    I seem to have hit a bit of a problem, when I compile the code everything is fine it shows 0 errors 0 warnings but 2 suppressed (cant seem to get any output on these).
    However when I go to program the PIC with the compiled code it just loops forever on programming and will not actually write to the PIC.
    I have checked all settings including con bits all is fine, I had an issue like this before when i placed a return in the code without anything to return to but that is no longer the case... I am stuck
    EDIT: Nevermind power ran out on the pack powering the board
    Sep 2010
    Hi Guys,
    According to the manual, the "BUTTON" function acts as a "GOTO" to a defined label (the last argument) with the added bonus of disabling auto-repeat and or debounce... does anybody know if the same can be used to GOSUB?
    or know of a solution to do the same?
    Since I have loops within loops the button presses keep being registered, but I cannot use the BUTTON function to GOTO since it will reset the count on the main loop
    MAIN:
      FOR CNT2 = 1 TO CNT
      IF PORTA.3 = 1 THEN GOSUB SHIP
      IF PORTA.0 = 1 THEN GOSUB FIRE
      IF CNT2 == CNT THEN GOSUB ADD
      GOSUB LCDUPDATE
      PAUSE 5
      NEXT
      GOTO MAIN
    As you can see I am using GOSUB as to not interrupt the "for..next" loop doing the count, but I need a way of stopping auto repeat on the button checks... (without pausing since this messes up the count timing) unless there is another way to have a definitive count?
    (watchdog timer perhaps? never used it)
    Basically so that when the user presses the button it will only increment by 1 and not auto repeat (due to the instructions per second) and increment by about 70 per press
    Any help will be greatly appreciated!
