PBP projects for R/C models
Results 1 to 40 of 772
    malc-c's Avatar
    malc-c Guest
    This new Transmitter, Receiver, ESC combo is different. Leaving out my PIC for the moment if I on the radio transmitter I give full forward (trigger full back) and suddenly go to full reverse (trigger full forward) the car goes from full forward to stop (neutral in the PWM sense) and stays there until I bring the trigger to neutral for at least two seconds. Then giving it full back will work fine.
    Ken
    Electronic braking system. - You might be able to go into the programming mode and disable this function.
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by malc-c View Post
    Uhmm maybe that's not an option. I can't see anything on programming the end points on this controller
    Nov 2009
    Fitchburg, Mass
    Default Just got back into town...
    OKAY,
    I have discovered through the use of my oscilloscope that PAUSE stops the HPWM output pulses. In order to emulate the radio system I want to try giving the ESC two seconds worth of neutral PWM between switches back and forth between forward and reverse. This is a race car. It will not be going backwards very often, but it is necessary sometimes. Looks like I need to figure out how to set a two second interrupt. Hmmmm. NUTS!
    Ken
    Hey Ken, welcome back to town.
    Do you mind posting some of your code for us to figure out what is going on? The HPWM command, or using the CCP hardware PWM with your own commands should both work independently of your code. I have a 2 second pause that is repeated, but HPWM keeps pumping out pulses the entire time. But if I repeatedly call HPWM and set it using PBP, it can give me some screwy results. Probably better setting the registers directly, like Bruce shows in this example: http://www.picbasic.co.uk/forum/show...1478#post61478
    What PIC hardware are you using?
    Walter
    http://www.scalerobotics.com
    Nov 2009
    Fitchburg, Mass
    Red face I'm using a 16F887
    Here is the first couple commands of my code. I deliberately start HPWM then PAUSE for four seconds. My oscilloscope shows a flat line for four seconds then springs in PWM action.
    I just looked at it again. I am no longer as certain as I was. Once I get into my code it seems to behave as I expect. I'll get back to you all tomorrow.
    Thanks, Ken
    Nov 2009
    Fitchburg, Mass
    Default Here's some code.
    The outputs of PORTC.1 and PORTC.2 are high all the time.
    Why? In other code snippets PAUSE seems to allow action to continue. I hope you guys see that I am being stupid.
    ' PORTC.0 'High is R/C.  Low is PIC control
    TRISC = %11110000
    low portc.0
    gosub straightforward
    pause 4000
    StraightForward:
    pwm 1,120,50
    pwm 2,120,50
    Nov 2009
    Fitchburg, Mass
    Default I see it already
    As soon as I typed "submit" I saw that I had left out the H in HPWM. Thank you sooo much!
    Ken
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
    Last Post: - 28th September 2021, 11:26
    By forgie in forum General
