I remember reading somewhere that for a 1/2 wave antenna you don't need a ground plane, is that an option here?For something permanent that would be good, but you still need a ground plane with any 1/4 wave antenna.
Is the wire then attached to the plate or the RX device?For prototyping I use a wire stuck into a bread board with the bread board setting on an aluminum plate.
