12f675_fuse_about_to_blow!
Results 1 to 40 of 929
    For something permanent that would be good, but you still need a ground plane with any 1/4 wave antenna.
    For prototyping I use a wire stuck into a bread board with the bread board setting on an aluminum plate. The plate is connected to ground (zero rail).
    http://www.arrl.org/files/file/Techn...df/6201025.pdf
    http://www.arrl.org/files/file/Techn...20Radiates.pdf
    Feb 2010
    I live in the UK
    I remember reading somewhere that for a 1/2 wave antenna you don't need a ground plane, is that an option here?
    Is the wire then attached to the plate or the RX device?
    Quote Originally Posted by LEDave View Post
    Yes but it will basically need two 1/4 wave wires. the ground plane sorta takes place of the second wire. 1/2 wave has advantages but for a portable the 1/4 wave is the most practical.
    The wire is the 6.5 inch antenna. Name:  TX_RX_ANT.jpg
    Using the above setup I can get .5 mile line of site with these.
    http://www.rentron.com/remote_control/TWS-434.htm
    http://www.rentron.com/remote_control/RWS-434.htm
    Feb 2010
    I live in the UK
    I see, does it have to be an aluminium plate or would a good size piece of vero board be ok.
    I liked those RENTRON TX_RX modules, I don't think for one moment they'd ship to the UK? Probably cost too much in postage, then again the module price was excellent.
    Has to be electrically conductive.
    Probably find something in the kitchen that would work....
    Feb 2010
    I live in the UK
    I've just tried a small aluminium vice from the shed and an aluminium tray (from the kitchen funnily enough ) the vice added another 5 - 10 yards, the tray not so much. I had a few funny looks from the neighbours every time I waved back at Mrs LEDave to say an LED had blinked as I walked up the street.
    I'm sure the distance can be boosted with some more tweaking.
    My neighbors moved...
    The antenna is half of the radio. It is the one part that is easy to tweek.
    If you really want to get into antennas the arrl.org site has a ton of info. I keep the ARRL Antenna Handbook close. About as bad as a data sheet though, 900+ pages of good info.
