12f675_fuse_about_to_blow!
Results 1 to 40 of 929
    Feb 2010
    I live in the UK
    Hi mackrackit,
    I've had a: " Small breakthrough for mankind, a giant breakthrough for me" evening.
    I've managed to get the Demo_prog to run. LED's D0 & D1 light when the push buttons are pressed, so very pleased with that.
    The TX range was a little on the low side at about 50 yards, 200 would be fantastic. I'm going to make a stand alone receiver board next and see how that goes.
    Always good to get something working
    COOOOL!!!
    Range-- What are you using for an antenna?
    1/4 wave (6.5 inches) wire over a ground plane?
    Feb 2010
    I live in the UK
    At the moment it's a single wire (AWG 24) approx 6.5" long.
    The booklet says: "Alternatively, the pin receptacle can be removed and an alternative antenna connection can be made. For example a coaxial wire can be connected to the antenna pad on the front side of the pcb and ground pad on the back side of the pcb."
    Early days yet but would one of these be any better?
    http://www.maplin.co.uk/Module.aspx?ModuleNo=35648
    For something permanent that would be good, but you still need a ground plane with any 1/4 wave antenna.
    For prototyping I use a wire stuck into a bread board with the bread board setting on an aluminum plate. The plate is connected to ground (zero rail).
    http://www.arrl.org/files/file/Techn...df/6201025.pdf
    http://www.arrl.org/files/file/Techn...20Radiates.pdf
    Feb 2010
    I live in the UK
    I remember reading somewhere that for a 1/2 wave antenna you don't need a ground plane, is that an option here?
    Is the wire then attached to the plate or the RX device?
    Quote Originally Posted by LEDave View Post
    Yes but it will basically need two 1/4 wave wires. the ground plane sorta takes place of the second wire. 1/2 wave has advantages but for a portable the 1/4 wave is the most practical.
    The wire is the 6.5 inch antenna. Name:  TX_RX_ANT.jpg
    Using the above setup I can get .5 mile line of site with these.
    http://www.rentron.com/remote_control/TWS-434.htm
    http://www.rentron.com/remote_control/RWS-434.htm
    Feb 2010
    I live in the UK
    I see, does it have to be an aluminium plate or would a good size piece of vero board be ok.
    I liked those RENTRON TX_RX modules, I don't think for one moment they'd ship to the UK? Probably cost too much in postage, then again the module price was excellent.
