Hi Alain,
Thank you for posting the examples. May I impose to ask about the analog signal you're measuring and how it relates to degrees port and starboard? It seems you're sensing the port and starboard switch over at 4.020 volts (adc value 823). I'm just wondering if you couldn't use a different formula to produce the same results and eliminate the step of converting adc values of 0..1023 to voltage 0..4995-mvolts).
Kind regards, Mike
