Help in sending hex string using serout
Results 1 to 6 of 6
    Oct 2008
    Default Help in sending hex string using serout
    Hello everybody,
    I'm trying to send hex values with SEROUT, unfortunately I'm getting errors with the syntax and also tried to use
    SerOut PortC.6,84, ["0x02 0x52 0x04 0x0b 00 0x61 0x0A 0x4D 0x6f 0x62 0x6f 0x74 0x20 0x49 0x49 0x49 00 0x03"]
    hope someone here can help..
    regards,
    mbox
    The command that you posted, is not correct. Use modedefs.bas with the Serout and at mode the nams like T2400 or N9600 etc. Look at the manual for he correct syntax.
    Now about the numbers, since they are inside "" they are treated as a long string message.
    Oct 2008
    Hello Ioannis,
    Thanks for the reply....
    Here is the whole code
     Include "modedefs.bas"
    CLEAR
     TRISC = %10000000'set TX (PORTC.6) to out, rest in
     TRISB = %00000000
     PortB = %00000000
     pause 20
     SerOut PortC.6,T9600, ["0x02 0x52 0x04 0x0b 00 0x61 0x0A 0x4D 0x6f 0x62 0x6f 0x74 0x20 0x49 0x49 0x49 00 0x03"]
     pause 10
     SerOut PortC.6,T9600,["0x02 0x52 0x66 00 00 0xb8 0x03"]
     pause 10
     Serout PortC.6,T9600, ["0x02 0x52 0x04 0x0b 00 0x61 0x0A 0x4D 0x6f 0x62 0x6f 0x74 0x20 0x49 0x49 0x49 00 0x03"]
    Can you help me send the hex values in the proper format?
    regards,
    mbox
    Take a look at SEROUT2.
    Then you can format it something like this
    HEX 42, HEX 24, ...
    And note that with Serout2 that Dave showed you, a HEX modifier can have a digit also impying the number of digits to follow.
    HEX2 means 2 hex digits etc.
    Oct 2008
    Thanks everyone for the responce... I finally got it...
    I use this in my code to send
    SerOut2 PortC.6,84, [$02,$52,$27,$06,$00,$7F,$12,$13,$23,$17,$09,$00,$03]
