after all ... PBP is not so bad ...
Results 1 to 24 of 24
    Smile
    Quote Originally Posted by Mike, K8LH View Post
    Hi Alain,
    Was it too late for the original student to use this new formula considering the time constraints you mentioned?
    Regards, Mike
    Halas yes, Mike ... He PMed me he had no time to change his report and explain how to simplify the formula, once having seen the practical result, so he had to use the whole original formula for programming ...
    despite I sent him the reduced program.
    no " magics " allowed in such reports ...
    he's just authorized to mention the soft can be modified and reduced , while presenting his work at the blackboard ... and next year students will make the mod ...
    But ... being honest ... you've cheated a bit !!!
    Aug 2005
    Michigan, USA
    How so? If you mean that I took advantage of all your hard work and careful analysis when I simplified the formula then you are correct (LOL).
    2) as the input swings from 3.02v to 5.02 v ... the output value is ... 26 starboard to 26 port ...
    Your summary made it easy to recognize the ralationship of 52° spread across 100 (8-bit) or 400 (10-bit) ADC counts. You really should have spotted this yourself when you wrote it (LOL).
    Anyway, I'm sorry the student could not take advantage of the simplified formula.
    Regards, Mike
