Yes, that's weird. Sometimes I forget to remove the programmer from my circuit and when the programmer is off and connected to the circuit my PIC won't work. So, in order to make my PIC work I need to either turn the programmer on or disconnect it from the circuit.
In your case, what voltage are you feeding MCRL with? Are you sure you are getting this voltage at MCRL? Try replacing the 4.7k resistor also. Try connecting an inductor in series with the 4.7k resistor or a 0.1uF capacitor from MCRL to ground close to the MCRL pin to eliminate posible noise.
