Here you go
What happens if you turn the MCLR diode around?
MCLR OFF is not an option for that part. Would be nice if it was...
Agreed about the full reset. Could save some problems down the road.
Good catch. Yes, Tobias definetely needs to turn that diode around or it won't work. He can even damage other components in his circuit with the ~12V going to Vpp from the programmer.
I have a design with a 16F727 where I use a diode and a 4.7k resistor connected to MCRL. Now, reading Joe_S post I just realized that I don't really need this two extra components in my design. In the 16F727 you can configure pin 1 as MCRL or as RE3.
Guys I appreciate the input and I realize that I have the diode drawn backwards in the schematic compared to the board. The PIC doesn't even program if the diode is backwards.
The question I have is what happens when I touch the MCLR line with the scope? When I do that, the PIC starts up. Thats the weird deal. I am back at my office now and am going to swap out diodes. Maybe there is just a problem with the diode.
I will let you know what I find.
Thanks again
Yes, that's weird. Sometimes I forget to remove the programmer from my circuit and when the programmer is off and connected to the circuit my PIC won't work. So, in order to make my PIC work I need to either turn the programmer on or disconnect it from the circuit.
In your case, what voltage are you feeding MCRL with? Are you sure you are getting this voltage at MCRL? Try replacing the 4.7k resistor also. Try connecting an inductor in series with the 4.7k resistor or a 0.1uF capacitor from MCRL to ground close to the MCRL pin to eliminate posible noise.
the 876 is not so easy with its reset pin ...I have numerous examples ...
I always use MC33064P5 TO92 supply supervisors and never have any power up problem.
a good habit is always enable the Brownout option ... 75% of problems off !!!
