mackrackit, Why are you using 10 k's for the pullup's? I believe the spec. says 4.7K or lower.. Might be the problem....
The data sheet for this part call for 10k at 100 kHz and 2k for 400 kHz and 1 MHz.
It did not work at the higher speeds so I was trying it at the slow.
I have tried several different resistor sizes and still nothing.
I think I am actually communicating with it as it "ACK" backs at me...
Here is my current mess...
Code:' 18F6680 24FC1025 DEFINE OSC 20 @ __CONFIG _CONFIG1H, _OSC_HS_1H @ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H @ __CONFIG _CONFIG4L, _LVP_OFF_4L TRISF = 0 PORTF = 0 DPIN VAR PORTF.6 'I2C DATA PIN CPIN VAR PORTF.7 'I2C CLOCK PIN CONTR CON %10100001 'READ CONTROL CONTW CON %10100000 'WRITE CONTROL ADDR_HB VAR BYTE ADDR_LB VAR BYTE DATI VAR BYTE DATO VAR BYTE ACK VAR BIT ADDR_HB = %00000000 ADDR_LB = %00000000 DATO = %11100000 CNT VAR BYTE CNT = 0 START:CNT = CNT + 1 GOSUB WRITE_DATA PAUSE 100 GOSUB READ_DATA SEROUT2 PORTB.2, 16572,["TEST ",DEC CNT,$d,$a] Serout2 PORTB.2, 16572,["DATA IN ",BIN DATI] SEROUT2 PORTB.2, 16572,[$d,$a] PAUSE 500 GOTO START WRITE_DATA: ACK=1 :Serout2 PORTB.2, 16572,["ACK ",BIN ACK,$d,$a] GOSUB START_ROM SHIFTOUT DPIN,CPIN,1,[CONTW] SHIFTIN DPIN,CPIN,0,[ACK\1] Serout2 PORTB.2, 16572,["ACK ",BIN ACK,$d,$a] SHIFTOUT DPIN,CPIN,1,[ADDR_HB] SHIFTIN DPIN,CPIN,0,[ACK\1] SHIFTOUT DPIN,CPIN,1,[ADDR_LB] SHIFTIN DPIN,CPIN,0,[ACK\1] SHIFTOUT DPIN,CPIN,1,[DATO] SHIFTIN DPIN,CPIN,0,[ACK\1] GOSUB STOP_ROM PAUSE 10 RETURN READ_DATA: GOSUB START_ROM SHIFTOUT DPIN,CPIN,1,[CONTR] SHIFTIN DPIN,CPIN,0,[ACK\1] SHIFTOUT DPIN,CPIN,1,[ADDR_HB] SHIFTIN DPIN,CPIN,0,[ACK\1] SHIFTOUT DPIN,CPIN,1,[ADDR_LB] SHIFTIN DPIN,CPIN,0,[ACK\1] GOSUB START_ROM SHIFTOUT DPIN,CPIN,1,[CONTR] SHIFTIN DPIN,CPIN,0,[ACK\1] SHIFTIN DPIN,CPIN,0,[DATI\8] GOSUB STOP_ROM PAUSE 10 RETURN START_ROM: HIGH CPIN:HIGH DPIN:LOW DPIN:RETURN STOP_ROM: HIGH CPIN:LOW DPIN:HIGH DPIN:RETURN
I changed the Control Byte for the read and the write from this:
to this:Code:contR CON %10100001 contW CON %10100000
Thinking that because A2 is held high for it to operate then the control bit for A2 should also be a 1... here is the new code:Code:contR CON %10100011 contW CON %10100010
this is the output from hyperterm:Code:DEFINE I2C_SLOW 1 SO con 0 ' Define serial output pin T2400 con 0 ' Define serial mode contR CON %10100011 ' Define Control byte contW CON %10100010 ' Define Control byte addr CON %0000000000000111 ' 2 Byte Address of 7 addr2 CON %0000000000001000 ' 2 Byte Address of 8 D1 CON %00000111 B0 VAR BYTE ' Var for data being read B1 VAR BYTE ' Var for data being read B0 = 0 B1 = 0 I2CWRITE PORTB.1,PORTB.4,contW,addr,[D1] ' Send the byte 1 to address 7 PAUSE 10 ' Wait 10ms for write to complete I2CREAD PORTB.1,PORTB.4,contR,addr,[B1] ' Read address 7 into B1 I2CREAD PORTB.1,PORTB.4,contR,addr2,[B0] ' Read address 8 into B0 Serout SO,T2400,["Addr",#addr,":",#B1," and then Addr",#addr2,":",#B0,13,10] ' Print B1's Value in DEC
Like I said I don't know what it means but it sure is different then what I was getting.Code:Addr7:2 and then 2
Any thoughts as to why it now is reading a "2" and not 255 or 0??? Its almost like it read the last 2 bits of the write control byte as if the write command wrote the last 2 bits of the control byte to the EEPROM.
UPDATE:
I just switched the control byte to be:
and got this as an output (Note the "6" in Address 8 to begin and then it get over written to "255" the next go around):Code:contR CON %10100001 contW CON %10100010
also I know I'm writing to it because in the example output above I read address 6 with it too (not shown in the code but I added it after posting) and I was reading "255" every time. So this tells me that I am writing a "6" to address 8 but then on the second loop it gets over written/erased to "255" but the "2" in address 7 remains constant and in memory. Now keep in mind that no where in my code do I try to write to address 8 it just happens, more than likely from an over flow from the write to address 7. So basically the byte I am trying to write to 7 gets split into a "2" in address 7 and a "6" in address 8 then address 8 gets overwritten on the 2nd loop to a "255".Code:Addr7:2 and then Addr8:6 Addr7:2 and then Addr8:255 Addr7:2 and then Addr8:255 Addr7:2 and then Addr8:255 Addr7:2 and then Addr8:255
and when I do the control byte like this:
I get this (the same as having both A2 bits set to 1):Code:contR CON %10100011 contW CON %10100000
Code:Addr7:2 and then Addr8:2 Addr7:2 and then Addr8:2 Addr7:2 and then Addr8:2
Sorry, read the data sheet wrong. Nevermind
Whoops it dawned on me what I am doing by changing that Bit. I guess that my novice understanding of this made me stumble upon the fact that I am now writing and reading from a different Chip Select, but seeing how I only have the one chip I dont understand how its reading/writing chip 01 when it should be chip 00.![]()
So I guess where I was calling it the A2 bit its actually the A0 bit that I was changing.
How do you have pins A0 and A1 connected?
I have not had a chance to work on this today yet so I do not have any new news.
