How to read & write to a 25aa1024 (1 Mbit SPI Bus Serial EEPROM) via 16F88
Results 1 to 37 of 37
    Default Just for fun...
    Here is how to read and write to a Serial EEPROM using SHIFTIN/SHIFTOUT.
    Using a 24FC1025.
    Why???? Why not???
    I have the DATA and CLOCK pins pulled up with 2.7k resistors.
    Follow the code with the data sheet to understand what is going on.
    DEFINE OSC 20
    DPIN    VAR PORTB.2    'I2C DATA PIN
    CPIN    VAR PORTB.1    'I2C CLOCK PIN
    CONT1   CON %10100001  'READ CONTROL
    CONT0   CON %10100000  'WRITE CONTROL
    ADDR_HB   VAR BYTE
    ADDR_LB    VAR BYTE
    DATOW       VAR BYTE
    ACK            VAR BIT
    ADDR_HB = 0'%00000000
    ADDR_LB = 0'%00000000
    DATOW    VAR BYTE
    CNT VAR BYTE
    CNT = 0
    START:
        CNT = CNT + 1
        DATOW = 245
        GOSUB WRITE_DATA
        PAUSE 10
        GOSUB READ_DATA
        LCDOUT $FE,1,"TEST ",DEC CNT
        lcdout $FE,$C0,"DATA IN ",DEC DATI
        lcdout $FE,$90,"LB ",DEC ADDR_LB
        PAUSE 250
        GOTO START
        WRITE_DATA:
        ADDR_LB = ADDR_LB + 1
        GOSUB START_ROM
        SHIFTOUT DPIN,CPIN,1,[CONT0]
        SHIFTIN DPIN,CPIN,0,[ACK\1]
        SHIFTOUT DPIN,CPIN,1,[ADDR_HB]
        SHIFTOUT DPIN,CPIN,1,[ADDR_LB]
        SHIFTOUT DPIN,CPIN,1,[DATOW\8]
        SHIFTOUT DPIN,CPIN,1,[%1\1]
        GOSUB STOP_ROM
        PAUSE 10
        READ_DATA:
        GOSUB START_ROM
        GOSUB START_ROM
        SHIFTOUT DPIN,CPIN,1,[CONT1]
        SHIFTIN DPIN,CPIN,0,[DATI\8]
        GOSUB STOP_ROM
        PAUSE 10
        START_ROM:
        HIGH CPIN:HIGH DPIN:LOW DPIN:RETURN
        STOP_ROM:
        HIGH CPIN:LOW DPIN:HIGH DPIN:RETURN
    Make sure you have ANALOG turned off!!
    Mar 2010
    Minnesota, USA
    Thanks for the code guys! I will try it out on sunday when I get back.
    Mar 2010
    Minnesota, USA
    Default Mackrackit your code works :D
    Well I was able to get your code to work. I noticed when I was reading before using the I2CREAD I was getting all 255's and now I am reading using your code and still getting all 255's where ther is no data written so that is telling me that I was getting the I2CREAD to work before. I am now reading through all memory locations looking for the data I wrote to it before using the I2CWRITE command to try and figure out where it wrote it and why. Once this finishes I will post my findings and thoughts.
    Thanks again for the code.
    PS:
    I have not tried Dave's code yet
    UPDATE:
    I found the written data from my old code in Block 1 of the EEPROM. I am going to go back to the old code I had and try and make it work. I will post my findings
    Mar 2010
    Minnesota, USA
    Thumbs up Finally got it to work!!!
    First and foremost Thank You, Thank You, Thank You for all of your help guys I really do appreciate it.
    Here is the working Code:
    ' Define serial output pin
    SO      con     0
    ' Define serial mode
    T2400   con     0
    ' 2 Byte Address Vars
    addr1   var     word
    addr2   var     word
    addr3   var     word
    ' Vars for data being written
    D1      Var     Byte
    D2      Var     Byte
    D3      Var     Byte
    ' Vars for data being read
    B1      VAR     BYTE
    B2      VAR     BYTE
    B3      VAR     BYTE
    ' Set Data Bytes
    D1 = 7
    D2 = 6
    D3 = 5
    ' Set Address Bytes
    addr1 = 1
    addr2 = 2
    addr3 = 3
    I2CWRITE PORTB.1,PORTB.4,$A0,addr1,[D1]      ' Write a 1 to address 1
    PAUSE 10                                     ' Wait 10ms for write to complete
    I2CWRITE PORTB.1,PORTB.4,$A0,addr2,[D2]      ' Write a 2 to address 2
    I2CWRITE PORTB.1,PORTB.4,$A0,addr3,[D3]      ' Write a 3 to address 3
    I2CREAD PORTB.1,PORTB.4,$A0,addr1,[B1]      ' Read address 1 into B1
    I2CREAD PORTB.1,PORTB.4,$A0,addr2,[B2]      ' Read address 2 into B2
    I2CREAD PORTB.1,PORTB.4,$A0,addr3,[B3]      ' Read address 3 into B3
    Serout SO,T2400,["Addr",#addr1,":",#B1," and then Addr",#addr2,":",#B2," and then Addr",#addr3,":",#B3,13,10] ' Print B1's Value in DEC
    and it's out putting this to Hyperterm:
    Addr1:7 and then Addr2:6 and then Addr3:5
    The problem I had in the beginning was I had the SDA/SCL Pins wrong and I did not have the A2 pin Tied to +5V but after correcting those I had my control byte misunderstood and thats why it would not work. After changing the control byte back to $A0 with the A2 held High and the propper pins chosen for SDA and SCL it now works like it should.
    I hope this thread saves everyone a ton of time in the future with these chips I know I sure learned a ton from this little experiance
