How to read & write to a 25aa1024 (1 Mbit SPI Bus Serial EEPROM) via 16F88
Results 1 to 37 of 37
    When I get back tonight I am thinking of do some sort of bit banging, maybe that will work.
    mackrackit, Why are you using 10 k's for the pullup's? I believe the spec. says 4.7K or lower.. Might be the problem....
    The data sheet for this part call for 10k at 100 kHz and 2k for 400 kHz and 1 MHz.
    It did not work at the higher speeds so I was trying it at the slow.
    Mar 2010
    Minnesota, USA
    I am using 4.7K. Sorry I forgot to mention that I was doing that different from the schematic I posted.
    Did you get it to work?
    I have tried several different resistor sizes and still nothing.
    I think I am actually communicating with it as it "ACK" backs at me...
    Here is my current mess...
    '  18F6680  24FC1025
        DEFINE OSC 20
        @ __CONFIG    _CONFIG1H, _OSC_HS_1H
        @ __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
        @ __CONFIG    _CONFIG4L, _LVP_OFF_4L
        TRISF = 0
        PORTF = 0
        DPIN    VAR PORTF.6    'I2C DATA PIN
        CPIN    VAR PORTF.7    'I2C CLOCK PIN
        CONTR   CON %10100001  'READ CONTROL
        CONTW   CON %10100000  'WRITE CONTROL
        ADDR_HB    VAR BYTE
        ADDR_LB    VAR BYTE
        DATI    VAR BYTE
        DATO    VAR BYTE
        ACK     VAR BIT
        ADDR_HB = %00000000
        ADDR_LB = %00000000
        DATO = %11100000
        CNT VAR BYTE
        CNT = 0
        START:CNT = CNT + 1
        GOSUB WRITE_DATA
        PAUSE 100
        GOSUB READ_DATA
        SEROUT2 PORTB.2, 16572,["TEST ",DEC CNT,$d,$a]
        Serout2 PORTB.2, 16572,["DATA IN ",BIN DATI]
        SEROUT2 PORTB.2, 16572,[$d,$a]
        PAUSE 500
        GOTO START
        WRITE_DATA:  ACK=1   :Serout2 PORTB.2, 16572,["ACK ",BIN ACK,$d,$a]
        GOSUB START_ROM
        SHIFTOUT DPIN,CPIN,1,[CONTW]
        SHIFTIN DPIN,CPIN,0,[ACK\1]
        SHIFTOUT DPIN,CPIN,1,[ADDR_HB]
        SHIFTOUT DPIN,CPIN,1,[ADDR_LB]
        SHIFTOUT DPIN,CPIN,1,[DATO]
        GOSUB STOP_ROM
        PAUSE 10
        READ_DATA:
        GOSUB START_ROM
        SHIFTOUT DPIN,CPIN,1,[CONTR]
        GOSUB START_ROM
        SHIFTIN DPIN,CPIN,0,[DATI\8]
        GOSUB STOP_ROM
        PAUSE 10
        START_ROM:
        HIGH CPIN:HIGH DPIN:LOW DPIN:RETURN
        STOP_ROM:
        HIGH CPIN:LOW DPIN:HIGH DPIN:RETURN
    Mar 2010
    Minnesota, USA
    Default I made a break through I just don't know what it means :D
    I changed the Control Byte for the read and the write from this:
    contR    CON     %10100001
    contW    CON     %10100000
    to this:
    contR    CON     %10100011
    contW    CON     %10100010
    Thinking that because A2 is held high for it to operate then the control bit for A2 should also be a 1... here is the new code:
    DEFINE I2C_SLOW 1
    SO      con     0                           ' Define serial output pin
    T2400   con     0                           ' Define serial mode
    contR    CON     %10100011                   ' Define Control byte
    contW    CON     %10100010                   ' Define Control byte
    addr    CON     %0000000000000111           ' 2 Byte Address of 7
    addr2   CON     %0000000000001000           ' 2 Byte Address of 8
    D1      CON     %00000111
    B0      VAR     BYTE                        ' Var for data being read
    B1      VAR     BYTE                        ' Var for data being read
    B0 = 0
    B1 = 0
    I2CWRITE PORTB.1,PORTB.4,contW,addr,[D1]      ' Send the byte 1 to address 7
    PAUSE 10                                    ' Wait 10ms for write to complete
    I2CREAD PORTB.1,PORTB.4,contR,addr,[B1]      ' Read address 7 into B1
    I2CREAD PORTB.1,PORTB.4,contR,addr2,[B0]      ' Read address 8 into B0
    Serout SO,T2400,["Addr",#addr,":",#B1," and then Addr",#addr2,":",#B0,13,10] ' Print B1's Value in DEC
    this is the output from hyperterm:
    Addr7:2 and then 2
    Like I said I don't know what it means but it sure is different then what I was getting.
    Any thoughts as to why it now is reading a "2" and not 255 or 0??? Its almost like it read the last 2 bits of the write control byte as if the write command wrote the last 2 bits of the control byte to the EEPROM.
    UPDATE:
    I just switched the control byte to be:
    contR    CON     %10100001
    contW    CON     %10100010
    and got this as an output (Note the "6" in Address 8 to begin and then it get over written to "255" the next go around):
    Addr7:2 and then Addr8:6
    Addr7:2 and then Addr8:255
    also I know I'm writing to it because in the example output above I read address 6 with it too (not shown in the code but I added it after posting) and I was reading "255" every time. So this tells me that I am writing a "6" to address 8 but then on the second loop it gets over written/erased to "255" but the "2" in address 7 remains constant and in memory. Now keep in mind that no where in my code do I try to write to address 8 it just happens, more than likely from an over flow from the write to address 7. So basically the byte I am trying to write to 7 gets split into a "2" in address 7 and a "6" in address 8 then address 8 gets overwritten on the 2nd loop to a "255".
    and when I do the control byte like this:
    contR    CON     %10100011
    contW    CON     %10100000
    I get this (the same as having both A2 bits set to 1):
    Sorry, read the data sheet wrong. Nevermind
    Mar 2010
    Minnesota, USA
    Whoops it dawned on me what I am doing by changing that Bit. I guess that my novice understanding of this made me stumble upon the fact that I am now writing and reading from a different Chip Select, but seeing how I only have the one chip I dont understand how its reading/writing chip 01 when it should be chip 00.
    So I guess where I was calling it the A2 bit its actually the A0 bit that I was changing.
    How do you have pins A0 and A1 connected?
    I have not had a chance to work on this today yet so I do not have any new news.
