Should work?Code:@ __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L @ __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H DEFINE OSC 48
The external OSC does not matter to PBP here. The above should have the MCU running at 48MHz. That is what PBP cares about.
