DEFINE OSC Serout problem
Results 1 to 9 of 9
    Wink Not all CPU freq are available ....
    Hi, Bonxy
    the Question is ...
    Which freq do you want to run the CPU ??? ... here we just know you use a 20 Mhz external XTAL ...
    BUT which is YOUR " CPUDIV_OSCx_PLLy _1L setting ???
    note you can't run the CPU@ 20 Mhz ... using PLL and USB ( 16 or 24 Mhz only - PLL x4 or x6 ... ).
    The ONLY available CPU freq are 48, 32, 24 and 16 Mhz, when using USB
    20Mhz need using only HS oscillator ... no USB then !!!
    Soooo ... nothing strange ...
    Try 24 Mhz ... and do not forget the " DEFINE "...
    Take a look at table 2-3 in the data sheet to see the different options.
    Dec 2004
    Scarborough UK
    Hi, Bonxy
    the Question is ...
    Hi Alain
    I am using (and want to use) 20mhz xtal and the usb is working fine at that speed (pll x5)
    but serout will not work at that speed, but if i change speed to "define osc 12" serial works, (although it should not as osc is still 20mhz) & usb wont work.
    So it seems its one or the other ?.
    Reading the datasheet & understanding it are two different things.
    @ __CONFIG   _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    @ __CONFIG   _CONFIG1H, _FOSC_HSPLL_HS_1H
    DEFINE OSC 48
    Should work?
    The external OSC does not matter to PBP here. The above should have the MCU running at 48MHz. That is what PBP cares about.
    Dec 2004
    Scarborough UK
    Talking
    DEFINE OSC 48
    Should work?
    Hey mackrackit
    The DEFINE OSC 48 works!, although I dont understand why (the crystal is still 20mhz), but who cares, both usb and serout are working now.
    Thanks dude
    Default configs, configs
    Quote Originally Posted by Bonxy View Post
    It is because you have to have the OSC configuration settings correct. And with so many options with these PIC18 chips, you have to read the data sheet a lot of times to get them right. (At least that is speaking for myself!) If you have (almost) any one of them set incorrectly, you will be running at the wrong speed, or worse, not run at all. But it does give you great flexibility.
    Here are your config options just for the oscillator on a pic18f4550:
    ;----- CONFIG1L Options --------------------------------------------------
    _PLLDIV_1_1L         EQU  H'F8'    ; No prescale (4 MHz oscillator input drives PLL directly)
    _PLLDIV_2_1L         EQU  H'F9'    ; Divide by 2 (8 MHz oscillator input)
    _PLLDIV_3_1L         EQU  H'FA'    ; Divide by 3 (12 MHz oscillator input)
    _PLLDIV_4_1L         EQU  H'FB'    ; Divide by 4 (16 MHz oscillator input)
    _PLLDIV_5_1L         EQU  H'FC'    ; Divide by 5 (20 MHz oscillator input)
    _PLLDIV_6_1L         EQU  H'FD'    ; Divide by 6 (24 MHz oscillator input)
    _PLLDIV_10_1L        EQU  H'FE'    ; Divide by 10 (40 MHz oscillator input)
    _PLLDIV_12_1L        EQU  H'FF'    ; Divide by 12 (48 MHz oscillator input)
    _CPUDIV_OSC1_PLL2_1L EQU  H'E7'    ; [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
    _CPUDIV_OSC2_PLL3_1L EQU  H'EF'    ; [OSC1/OSC2 Src: /2][96 MHz PLL Src: /3]
    _CPUDIV_OSC3_PLL4_1L EQU  H'F7'    ; [OSC1/OSC2 Src: /3][96 MHz PLL Src: /4]
    _CPUDIV_OSC4_PLL6_1L EQU  H'FF'    ; [OSC1/OSC2 Src: /4][96 MHz PLL Src: /6]
    _USBDIV_1_1L         EQU  H'DF'    ; USB clock source comes directly from the primary oscillator block with no postscale
    _USBDIV_2_1L         EQU  H'FF'    ; USB clock source comes from the 96 MHz PLL divided by 2
    ;----- CONFIG1H Options --------------------------------------------------
    _FOSC_XT_XT_1H       EQU  H'F0'    ; XT oscillator, XT used by USB
    _FOSC_XTPLL_XT_1H    EQU  H'F2'    ; XT oscillator, PLL enabled, XT used by USB
    _FOSC_ECIO_EC_1H     EQU  H'F4'    ; External clock, port function on RA6, EC used by USB
    _FOSC_EC_EC_1H       EQU  H'F5'    ; External clock, CLKOUT on RA6, EC used by USB
    _FOSC_ECPLLIO_EC_1H  EQU  H'F6'    ; External clock, PLL enabled, port function on RA6, EC used by USB
    _FOSC_ECPLL_EC_1H    EQU  H'F7'    ; External clock, PLL enabled, CLKOUT on RA6, EC used by USB
    _FOSC_INTOSCIO_EC_1H EQU  H'F8'    ; Internal oscillator, port function on RA6, EC used by USB
    _FOSC_INTOSC_EC_1H   EQU  H'F9'    ; Internal oscillator, CLKOUT on RA6, EC used by USB
    _FOSC_INTOSC_XT_1H   EQU  H'FA'    ; Internal oscillator, XT used by USB
    _FOSC_INTOSC_HS_1H   EQU  H'FB'    ; Internal oscillator, HS used by USB
    _FOSC_HS_1H          EQU  H'FC'    ; HS oscillator, HS used by USB
    _FOSC_HSPLL_HS_1H    EQU  H'FE'    ; HS oscillator, PLL enabled, HS used by USB
    _FCMEN_OFF_1H        EQU  H'BF'    ; Fail-Safe Clock Monitor disabled
    _FCMEN_ON_1H         EQU  H'FF'    ; Fail-Safe Clock Monitor enabled
    _IESO_OFF_1H         EQU  H'7F'    ; Oscillator Switchover mode disabled
    _IESO_ON_1H          EQU  H'FF'    ; Oscillator Switchover mode enabled
    Walter
    And...
    The OSC is not running the chip, it is running the PLL, That is why the 48MHz works.
    With the correct config settings you can run at 48MHz with a 4MHz external.
    Another cool thing is the different voltages this allows. Normally you have to use 5 volts to run a chip at 20MHz, with a 4MHz and the correct configs you can run this chip with 2 volts at 48MHz. For USB though you will not want to go lower than 3.3 volts, so that way the whole system can run at "low" voltages at "high" speeds. Really nice when using things like SD cards, some RTC, and other things that only run on ~3 volts.
    Talking
    Hi, Bonxy
    You had the answer @ post 2 ...
    But why do I loose my youth here ??? I really wonder why ...
