12f675_fuse_about_to_blow!
Results 1 to 40 of 929
Threaded View
  1. #10
    Yes, the code Joe wrote is in done in PBP.
    BASICS....
    When you get your PBP CD there will be a program there called Micr Code Studio (MCS). This is where you will write your code. You can use other editors but MCS is probably best for starters.
    Copy Joe's code into MCS or write your own. There are config fuses that need set, Joe did not include that but we can go over that when you are ready.
    Once you are happy with the code there is e a "button" in MCS to click and PBP runs to compile the code into HEX. The HEX is saved in your project directory.
    The PICkit1 has software of its own. Open that and open the HEX created by PBP using MCS. There will be a "Write" button in the PICkit software. ( you already know about that I guess).
    My web site is a work in progress. I hope it will help someone along the way.
