Finally is pickit's app bug.
Just installed pickit 2.01 with the according firmware and all ok!!
(next up is to see in which version introduced this bug , i will post as soon as i have results...
result: PICKIT 2.40 is the latest working ok.
I doubt that...
The PICkit2 does not have a socket. How do you have it connected?ps....
Found a strange solution...I program the PIC , i remove PIC from the socket , Close App , then Re-open App , Insert PIC in socket , Read PIC and data is now OK.
Seems that something destroys the 8 bytes while closing or opening the PICKIT2 programer software..
with a small 40pin ICsocket > 6pin breadboard...
I retried second time to use 2.55 still not working, so back to 2.40 for sure.
I suspect is a bug of the Firmware 2.32.00 used both in 2.61 and 2.55.
I had the similar problem with PICkit 2 and 16F88. When PICkit 2's software was re-opened, a READ operation would erase some or all of the programming. The problem went away when I used chose Manual Device Select instead of automatic select. SW v2.61.
