PIC16f877A first 8 bytes destroyed after closing PicKit2 programmer app....
Results 1 to 10 of 10
Threaded View
  1. #2
    Quote Originally Posted by LakisFM1 View Post
    Hello to the forum,
    Using PicKit2 i write/verify a hex file on 16F877A , all ok.
    I even load another file and back read the 877A and all still ok.
    BUT then i close the pickit application,
    when i re-open Pickit application and read the 877A the first 8 bytes are FF , the rest bytes are proper.
    My program has nothing to do with on-the-fly code-programming to overwrite the first 8 program memory bytes ...
    The program is (now only a simple port-toggle , problem is still happening ...)
    OPTION_REG.7 = 0 ; ENABLE PORTB PULLUPS
    LOOP:
    portb.0 = not portb.0
    GOTO LOOP
    Hello LakisFM1,
    Welcome to the forum !
    I have some thoughts, which manifest as questions.
    Here goes . . .
    Are you compiling this code using PBP and MCS ?
    If so, Make sure to choose, " Compile " and Not, " ICD Compile " There is a world of difference in the hex output between these. As I usually do not use the ICD, I have unchecked it's selection in the toolbar settings, so as to avoid tripping myself.
    EDIT: Anyway here is your code working for me
    TRISB = 0
    LOOP:
    portb.0 = NOT portb.0
    PAUSE 500
    GOTO LOOP
  1. Help MCS with PICKIT2 programmer question
    By luminas in forum mel PIC BASIC Pro
    Last Post: - 1st February 2008, 17:57
