Can PBP & 16f88 really do 9600,8,E,1
Results 1 to 39 of 39
    Dec 2005
    What version of PBP? Using MPASM or PM?
    I get the same syntax error (Expected "]") on a similar (mine includes a timeout label & value) statement using PBP 2.50 and MPASM.
    HSerIn 15,init,[WAIT($FF,$05),addr)
    Dec 2005
    Sorry, the closing ")" was a typo - my router quit yesterday and I had to manually type that line instead of copying it across my network.
    The reason my test failed was because addr was not declared. The error message is a bit cryptic.
    Have you declared the correct number of array elements for DATAIN?
    My complete code is here. Sadly I have now deleted the troublesome line and replaced it with two lines. I am using PBP 2.50 and PM
    ' PBP BCM CODE 22/10/09 V.04 8mhz
    @ DEVICE PIC16F88,INTRC_OSC_NOCLKOUT
    @ DEVICE PIC16F88,PROTECT_OFF
    @ DEVICE PIC16F88,WDT_OFF
    @ DEVICE PIC16F88,PWRT_ON
    @ DEVICE PIC16F88,MCLR_ON
    @ DEVICE PIC16F88,BOD_OFF
    @ DEVICE PIC16F88,LVP_OFF
    @ DEVICE PIC16F88,CPD_OFF
    @ DEVICE PIC16F88,DEBUG_OFF
    @ DEVICE PIC16F88,CCPMX_OFF
    DEFINE OSC 8 			'Set oscilator speed to 8mHz
    OSCCON=%01111000 		'8 Mhz
    'DEFINE OSC 4 			'Set oscilator speed to 4mHz
    'OSCCON =%01100000		'4 Mhz
    DEFINE HSER_BAUD 9600		'Set Baud rate to 9600bps
    DEFINE HSER_BITS 9		'Set to 9 bit mode
    DEFINE HSER_EVEN 1		'Set Even Parity
    DEFINE HSER_CLROERR 1 		'Clear overflow error automatically
    ANSEL = 0 			'ALL DIGITAL
    CMCON = 7 			'COMPARATORS OFF
    INTCON = 0 			'Disable interrupts
    TRISB = %00000100 		'SET PORTB RB2(RX) as input, others to OUTPUT
    TRISA = %11111111 		'SET PORTA AS INPUTS
    'Variables
    BCMDATA VAR BYTE[12]		'Define BCMAADATA as a byte array (12 Bytes)
    Count1 VAR BYTE			'Define Count1 as a byte variable (Used in For/Next Loops)
    CheckSum VAR BYTE		'Define CheckSum as a byte variable
    Commloop: 				'Start of Communications Loop
        HSERIN [WAIT ($87)]		'Wait for Packet start Byte $87
    	HSERIN [STR BCMDATA\11]		'Receive 11 bytes into array BCMDATA
    	'Gosub CalcSum			'Gosub CalcSum to Calculate Checksum
        Hserout [$87]               'Transmit Packet start Byte $87
    	HSEROUT [str BCMDATA\11]	'Transmit 11 bytes from array BCMDATA
        HSERIN [WAIT ($AA)]		'Wait for Packet start Byte $AA
        Hserout [$AA]               'Transmit Packet start Byte $AA
    	Pause 32				'Pause for 16ms
        HSEROUT [$AA,$10,$00,$00,$00,$20,$40,$61,$10,$01,$00,$74]		'Transmit 12 bytes
        pause 32                'Pause for 16ms
        HSEROUT [$87,$40,$58,$15,$6E,$10,$01,$32,$2F,$2F,$04,$39]		'Transmit 12 bytes
        goto CommlooP			'Goto Loop
    CalcSum:					'Calculate Packet CheckSum Routine
    	CheckSum = 0				'Clear CheckSum Variable
    	For Count1 = 0 to 10			'For Count1 = 0 to 10 (Start 11 byte loop)
    	CheckSum = CheckSum + BCMDATA[Count1]	'Add Bytes
    	Next Count1				'Repeat until 11 bytes added
    	CheckSum = NOT CheckSum			'Not CheckSum
    	CheckSum = CheckSum + 1			'Add 1 to CheckSum
    	BCMDATA[12] = CheckSum AND $7F 		'AND result
    	Return					'Return
    However i have just tried this.
     HSERIN [WAIT($87), str BCMDATA\11]		'Receive 12 bytes into array DATAIN
    And it compiles correctly, might have been me with a typo!!!!! Arrggh. I let you know. Thanks for the help so far. This program is just proof of concept at the moment I know the "gosub" is not called at the moment. I'm trying to get the hserin/out working first.
    Anything with my configs or program that would stop a pickit2 icsp working I can't get that to work for love or money, but the chip works fine in a standalone programmer. I've checked the circuit and pickit2 voltages and it all looks fine. Just can't find device 99% of the time.
    Quote Originally Posted by retepsnikrep View Post
    Do you have capacitors across VDD and VSS??
    Dec 2005
    HSEROUT [$AA,str BCMDATA\11]
    will be slightly faster.
    Thanks that's helpful. I'm pretty clued up with picaxe basic but am now trying to move over and the syntax for PBP is quite a bit different.
    The schematic looks OK to me.
    Does the PicKit work with other chips?
    Do you have a regular breadboard to put the chip in and try the PicKit from there?
    My board is pretty standard with the ICSP pins and a 10k pullup on MCLR pin.
    It is powered by a 7805 100ma reg from a 12v bench psu. 1000uf on each side of reg + 0.1uf on vdd/vss pins of 16f88. I tried adding extra cap 10uf tantalum across vdd/vss no change. Are my 1000uf a bit big?
    Tried powering it from a 9v battery via reg. No apparent change.
    Connections checked on board using pickit2 software and it is supplying the correct voltages inc 12v on MCLR under trouble shooting mode.
    The chip does work in the board when programmed off board and is communicating as per my current software.
    Once every few trys it will communicate briefly but always reports errors or can't find device.
    Once the chip is running in the board I can't communicate with it. If I insert it blank into the board I can communicate initially but it does not program sucessfully and then I loose comms and have to erase it in my other programmer and program it with that!
    The board looks like this.
    http://www.solarvan.co.uk/bcm/fakebcm004.jpg
    My untidy schematic here.
    http://www.solarvan.co.uk/bcm/BATTSC..._INTERFACE.jpg
    I appreciate the help thanks.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. PBP migration from 16F88 to 16F1827
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 21st June 2010, 19:14
  3. PBP, ASM and LST files
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 12th January 2010, 14:43
  4. Compiler differences between PBP 2.33 & 2.46
    Last Post: - 2nd May 2006, 20:01
  5. Newby- PBP wont compile for 18F (MPLAB)
    Last Post: - 18th December 2005, 00:30
