Two Issues with PICbasic's Efficiency
Results 1 to 12 of 12
    M25PE80... The memory can be written or programmed 1 to 256 bytes at a time.
    Improved over old M25P series?
    I found with the previous M25P series after many 1 byte writes errors crept
    in thus a full 256 byte sector write was used.
    Norm
    May 2009
    Norm
    Thanks Norm the your suggestions and the sample codes. IN the manual it sounds like 1~256 is a flexiable range that can be written. Any way I will try it out later.
  1. SERIN2 buffer issues...
    Last Post: - 16th October 2008, 04:49
  2. Solved: notes on annoying little issues
    By Probotics in forum mel PIC BASIC Pro
    Last Post: - 26th May 2008, 21:02
  3. Where should I discuss SD/MMC FAT issues?
    By JD123 in forum General
    Last Post: - 2nd April 2008, 22:41
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  5. Circuit reliability issues
    By hkpatrice in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2007, 15:55
