It is a feature of SERIAL EEPROM like the internal PIC EEPROM or external EEPROM (like the 24LC64 and similar etc) that require (up to) 10mS for a WRITE operation (consult the Datasheet of the EEPROM you are using for the actual timing). All the worlds fastest Assembly routines will not help you. You must use a faster hardware product like Alain suggested.
Sounds good. The EEPROMs require a 5ms wirting circle typically from Microchips. While it can be reduced to about 3ms as I tried.
