LCDOUT w/custom interface?
Results 1 to 5 of 5
    Aug 2005
    Michigan, USA
    Default LCDOUT w/custom interface?
    Someone on another Forum asked me if it's possible to use the LCDOUT function with my old Novelty Serial LCD Interface (a simple 1-pin interface experiment inspired by the Predko 2-pin shift-register interface).
    The interface uses standard Async' Serial data but in a rather exotic format where each byte is sent as two bytes, one nybble per byte, along with the LCD 'RS' bit.
    ;  host low level K8LH Novelty 12F635 Serial LCD Driver
    LcdCmd
            clrc                    ; C = RS = 0, 'command'           |B0
            skpnc                   ;                                 |B0
    LcdDat
            setc                    ; C = RS = 1, 'data'              |B0
            movwf   Temp            ; save data in WREG               |B0
            swapf   Temp,W          ; swap nybbles -> WREG            |B0
            call    LcdNyb          ; send left nybble                |B0
            movf    Temp,W          ; send right nybble               |B0
    LcdNyb
            andlw   0x0F            ; mask off left nybble            |B0
            skpnc                   ; RS = 0? yes, skip, else         |B0
            iorlw   b'11000000'     ; set the RS bits                 |B0
            btfss   PIR1,TXIF       ; transmit buffer empty?          |B0
            goto    $-1             ; no, branch, else                |B0
            movwf   TXREG           ; send byte                       |B0
            return                  ;                                 |B0
    Can the LCDOUT function use a custom driver like the one above (after being upgraded to catch the special $FE character)?
    Kind regards, Mike
    I must be missing the point. If it is wired as shown just use the normal LCDOUT. ???
    How is the 2 pin or 1 pin thing you mention wired?
    Hi, Dave
    I think this might be some kind of serial to parallell converter ... trying to use the minimum pin count device ...
    might be used for a very particular use ...
    The Question was " Can I use THAT with PBP "LCDOUT" Command ??? "
    so, the answer is NO ...
    May be some SEROUT2 with modifier for 4 bits data out ... ( to be confirmed )
    OK, I see what I was missing now. This is a LCD Backpack thing.
    Interesting...
    selina's Avatar
    selina Guest
    Default Re: LCDOUT w/custom interface?
    RA4 is an open drain output.
    You'll need a pull-up resistor on that pin.
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  2. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 08:31
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 03:33
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
