Someone on another Forum asked me if it's possible to use the LCDOUT function with my old Novelty Serial LCD Interface (a simple 1-pin interface experiment inspired by the Predko 2-pin shift-register interface).
The interface uses standard Async' Serial data but in a rather exotic format where each byte is sent as two bytes, one nybble per byte, along with the LCD 'RS' bit.
Can the LCDOUT function use a custom driver like the one above (after being upgraded to catch the special $FE character)?Code:; ; host low level K8LH Novelty 12F635 Serial LCD Driver ; LcdCmd clrc ; C = RS = 0, 'command' |B0 skpnc ; |B0 LcdDat setc ; C = RS = 1, 'data' |B0 movwf Temp ; save data in WREG |B0 swapf Temp,W ; swap nybbles -> WREG |B0 call LcdNyb ; send left nybble |B0 movf Temp,W ; send right nybble |B0 LcdNyb andlw 0x0F ; mask off left nybble |B0 skpnc ; RS = 0? yes, skip, else |B0 iorlw b'11000000' ; set the RS bits |B0 btfss PIR1,TXIF ; transmit buffer empty? |B0 goto $-1 ; no, branch, else |B0 movwf TXREG ; send byte |B0 return ; |B0
Kind regards, Mike
