Run a string of LEDs from the mains
Results 1 to 31 of 31
    Jun 2007
    Mansfield, UK
    falingtrea: If i use a transformer inside a device then would it make a difference? 240V would still be going into it so i would need to look at all that safety stuff anyway
    Quote Originally Posted by The Master View Post
    But the "safety stuff" would be isolated to one point.
    Jun 2007
    Mansfield, UK
    Thats a good point. Most of these projects would involve having the LEDs on the same board as the transformer but while testing its probably a good idea if most of the PCB has low voltage running through it
    mackrackit: This confuses me a bit. you say theres no need to worry with 5 LEDs on 12V but they could be a bit dim. Are you saying theres no need for any resistor? I wouldnt normally use a resistor in this case anyway.
    Now the wheels are turning...
    You tried 4LEDs across 12 volts with out a resistor. Put in a 220 or whatevere and see what happens to the color.
    I know this is all a bit confusing. Maybe another reason not to run from mains directly. At least not untill you get all of this sorted out.
    I think you need some basic classes on electronics. Maybe the Art of Electronics is a book all have to read first.
    That picture shows the relation between Current and Voltage. Do you notice how steep is the curve at the point where the diode starts to contact? A very little increase at Voltage and the current will be infinite!. Thats why a resistor is needed or even better a current source to stabilize the current at 30 or if you insist on decreasing ED life at 50mA.
    A battery is very constant and 12 will never be 13 volts without any good reason. But Power line? No ones guarantees the 240Vac. So what will happen to you precious diode (read LED) when the voltage across the pins moves away from the knee of the curve? Bam!
    Jun 2007
    Mansfield, UK
    Nothing happens to the color. What should i be seeing?
    The LEDs im using work on a min of 3V. They can go upto 4V if needed. With 80 LEDs that gives me an extra 80V to play with. If the voltage goes up over 320V then you would expect things to blow up anyway. If i were running 4 LEDs through a 12V transformer then i would expect 320V input to give me 16V output so still 4V per LED
    You should see a color change when running at the peak voltage.
    Just curious.... What does RMS stand for and how is applied to electronics?
    Which is why most companies buy an off the shelf power supply solution. The power supply company handles the safety issues. If a part already meets UL or IEC standards, you usually don't have to requalify the part when you submit your product that includes the pre-approved product.
    Tim Barr
  1. How about String Variables?
    By mytekcontrols in forum PBP Wish List
    Last Post: - 20th January 2015, 12:53
  2. Embedded Strings in your Code Space
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 07:50
  3. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
  4. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 04:39
  5. controlling leds with the switches
    By ilteris in forum mel PIC BASIC Pro
    Last Post: - 12th October 2005, 21:02
