Run a string of LEDs from the mains
Results 1 to 31 of 31
    mackrackit: This confuses me a bit. you say theres no need to worry with 5 LEDs on 12V but they could be a bit dim. Are you saying theres no need for any resistor? I wouldnt normally use a resistor in this case anyway.
    Now the wheels are turning...
    You tried 4LEDs across 12 volts with out a resistor. Put in a 220 or whatevere and see what happens to the color.
    I know this is all a bit confusing. Maybe another reason not to run from mains directly. At least not untill you get all of this sorted out.
    I think you need some basic classes on electronics. Maybe the Art of Electronics is a book all have to read first.
    That picture shows the relation between Current and Voltage. Do you notice how steep is the curve at the point where the diode starts to contact? A very little increase at Voltage and the current will be infinite!. Thats why a resistor is needed or even better a current source to stabilize the current at 30 or if you insist on decreasing ED life at 50mA.
    A battery is very constant and 12 will never be 13 volts without any good reason. But Power line? No ones guarantees the 240Vac. So what will happen to you precious diode (read LED) when the voltage across the pins moves away from the knee of the curve? Bam!
    Jun 2007
    Mansfield, UK
    Nothing happens to the color. What should i be seeing?
    The LEDs im using work on a min of 3V. They can go upto 4V if needed. With 80 LEDs that gives me an extra 80V to play with. If the voltage goes up over 320V then you would expect things to blow up anyway. If i were running 4 LEDs through a 12V transformer then i would expect 320V input to give me 16V output so still 4V per LED
    You should see a color change when running at the peak voltage.
    Just curious.... What does RMS stand for and how is applied to electronics?
    Jun 2007
    Mansfield, UK
    With 4 LEDs running on 12V they are all running at their lowest voltage. I have accidentally put too many volts into some of these LEDs before. They dont change color they just get slightly brighter and stop working after a few days.
    Do you mean root mean square? I think someone has mentioned this in one of my previous threads but i didnt quite understand it
    1. your typical 240 Vac when rectified will be 240 x 1.41 =338.4 Volts DC. But if line goes up to 250 then 250 x 1.41 = 352.5!
    So watch out.
    2. RMS is that AC voltage that represents the same thermal effect when an equal DC voltage is applied to the load. That is if your line is 240Vac and you put a resistor on the line, that resistor will get hot. If you then apply DC voltage, you have to apply exactly 240 Volts to have the same thermal effect.
    BUT note that 240Vac is not the maximum level that the line reaches. Is the peak of the sinus wave form and is 240x1,41.
    Feb 2008
    Michigan, USA
    The explanations that people are giving you are good but maybe a different one will help.
    A LED will pull WAY more current than is healthy for it if it is not restricted in some way. The color is one indication that things are going badly and in short order. The resistor is sized so that it limits the current to a safe level using Ohm's law. Limiting it to MAX will reduce the potential life of the LED. Common practice it to limit it to less than max, hence, the suggestion of 30 mA instead of 50 mA. The voltage rating is what is needed to light the particular material (they are different because they use different materials to give different colors).
    A quick look at a Digikey catalog gives a few examples:
    Color,forward voltage, max current
    Red, 2.0vdc, 25mA
    Green , 2.2vdc, 25mA
    Blue , 3.65vdc, 30mA
    You can run any of these off of a 12 v supply because there is more than enough to overcome the "bandgap" of the material, but you still need to limit the current to around 20 mA. (less than the max listed).
    The calculations are this:
    Red: 12.0v - 2.0v = 10v: 10v / .020A = 500 ohm
    Green: 12.0v - 2.2v = 9.8v: 9.8v / .020A = 490 ohm
    Blue: 12.0v - 3.65v = 8.35v: 8.35 / .020A = 417.5 ohm
    Common practice it to find the common value that is closest, but higher value, or if close, but lower (more current) recalculate and see how close you are to max and determine if you can live with the reduction in life.
    On a side note, if you put a 1n917 diode accidentally across 120v ac mains, they release their smoke explosively! ie: glass shards many feet away.
    Reading between the lines of your questions, prudent advise would be that lower voltage is much more likely to give you the chance to live a long and fruitful life.
    I will admit that the idea did intrigue me when I first read it. Outdoor IR illumination came to mind, but after mulling it over, even with 25 years of working around the "magic lightning" I decided I'm going to pass.
    Good luck
    Bo
    The little LED thumb sized flashlights are an interesting case in design. You open it and wonder why they don't need a resistor. The batteries are coin cells that are limited in the amount of current that they can supply even if shorted, so the current limit is a function of the batteries. If you supplied the same voltage from a power supply, the LED would smoke in short order.
  1. How about String Variables?
    By mytekcontrols in forum PBP Wish List
    Last Post: - 20th January 2015, 13:53
  2. Embedded Strings in your Code Space
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 08:50
  3. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  4. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
  5. controlling leds with the switches
    By ilteris in forum mel PIC BASIC Pro
    Last Post: - 12th October 2005, 22:02
