4 Bit LCD issue with interrupts
Results 1 to 16 of 16
    Feb 2005
    Kolkata-India
    Default I don't think so.
    Thanks Darrel for responding fast. I don't think there are banking issues. I use "CHK?RP", Banksel or sometimes and manually take care mpst of the times.
    I remembered have done this (4 bit) before on a 16F676 and used button scanning on the same bus as LCD. RBIF driven, didn't have any problem. It was on a 16F676 internal osc.
    Anything else ?
    Sougata
    Are the interrupt routines accessing or driving something that could be causing interference?
    Feb 2005
    Kolkata-India
    Default Nope
    Hi Mackrackit,
    Thanks for replying. In real life there would be EMI upsets (Contactors) but right now it is just on my desk. So interference rules out.
    Any asm LCD test routine out there, just to check if it is getting messed in the PBP routine. Since I am not using the R/W pin I believe PBP is putting preset delays rather than polling that pin. Is there a possibility that it gets messed there. Also strange things happen. Half display.
    Change the LCD too.
    Sougata
    Is the R/W pin connected to the zero rail?
    Feb 2005
    Kolkata-India
    Default Yes
    Yes, I am frustrated.
    Sougata
    If enabling Interrupts is causing the LCD to misbehave then...
    Is outputing to the LCD actually causing an interrupt?... ie have you connected the LCD to a pin that might itself be triggering an interrupt, and check your PIC that your LCD connections have not been bridged across to an adjacent pin that might be triggering an interrupt.
    Try to enable interrupts one by one to see which one (or which ones) are causing the problem. This might give you a clue where to look further.
    Quote Originally Posted by sougata View Post
    ... I use "CHK?RP", Banksel or sometimes and manually take care mpst of the times.
    Oooooo, that sounds scary.
    Do you use all 3 in the same program?
    That'll cause some banking problems if you do.
    Can you post or email me the ASM handlers?
    Feb 2005
    Kolkata-India
    Default Not really Darrel
    Hi all,
    Thanks Mel for looking. LCD is on PORTD.4 - PORTD.7 (MSSP turned OFF) RS/EN on PORTC 4, 5. So no sources of interrupt from there. Also as Darrel mentioned that LCD is a synchronous interface it should not matter much.
    If I am using some of your routines or macro or I2 (I.square a.k.a Instant Interrupt) and find that it is using the PBP macro for checking page or resetting to page zero then I use that. If I am using my own ISR I use banksel. Is this wrong ??
    Darrel I have never bothered how the data is actually transported to the LCD. I am studying now. Can there be issues if the timing between two nibbles get spoiled for the program doing too much in Interrupt.
    I am re-structuring the code and would post it here. Also I would use LCDs from different brands and see if this cheap Chinese LCD (In fact all that are available are Chinese) is a culprit.
    BTW I noticed that PBP sets the PINs as output every time LCDOUT is used. Was my observation correct. Can this be safely removed as I have manually set it as output and never use the LCDIN command in my prog.
    Sougata
    Feb 2005
    Kolkata-India
    Default Darrel Please Teach Me
    Although it is not the case for this prog, but I need to know. Can you please.... explain a more as I do not know much about PBP internals.
    Edit: BTW I found that using 8 bit is okay. That is why I named the thread 4 BIT LCD Prob.
    Sougata
    I can try ...
    I guess the biggest problem is with CHK?RP and RST?RP.
    Each time they're used, it saves it's result to an ASM variable called PREV_BANK.
    And the next time one's used, CHK?RP uses that PREV_BANK value to figure out if it needs to change the bank ... and if so ... which bits need to be set to use the least amount of code space.
    Using BANKSEL or setting the bank manually does not update the PREV_BANK variable, so PBP can get lost from not knowing which bank it's really in.
    Even GOTO's within an area of code that only uses CHK?RP can be problems.
    For instance with this code ...
    MyVar0   VAR BYTE BANK0
    MyVar1   VAR BYTE BANK1
       CHK?RP  _MyVar1      ; 1 - this will select BANK1
       movlw   12
       xorwf   _MyVar1,W
       btfss   STATUS,Z
       goto    Bypass
       CHK?RP  _MyVar0      ; 2 - this selects BANK0
       btfss   _MyVar0,5
       goto    ExitRoutine
    Bypass
       CHK?RP  _MyVar0      ; 3 - This statement does nothing. Although the intent
       movlw   34           ;  was to change to BANK0, the PREV_BANK from the
       movwf   _MyVar0      ;  last CHK?RP at step 2 says we're already in BANK0.
       goto    AnotherPlace ;  But if we got here from the goto Bypass in step 1 ...
                            ;  then BANK1 is still selected, and it will overwrite
                            ;  the wrong RAM location in BANK1.
    ExitRoutine
    PREV_BANK works line by line from the top of the program.
    GOTO's can bypass that logic.
    There are many different variations of the same problem, and BANKSEL or manually setting STATUS or BSR bits will only make it worse.
    Once you know how it works ... of course ... it's a piece of cake.
    Some of the ways around the problems are to use the LABEL?L, L?GOTO and L?CALL macros.
    Clear as MUD.
    Feb 2005
    Kolkata-India
    Default I did not understand why ?
    Clear as MUD.
    Thanks for the explanation.
    Using CHK?RP messes with the PREV_BANK variable. So if I use Banksel in my ASM routine (not within the main body of the program but ISR) would there be any problem ? If yes, then why ? Context is being restored automatically either through the shadow registers for High Priority or through your program if LP is used.
    Sougata
    ... So if I use Banksel in my ASM routine (not within the main body of the program but ISR) would there be any problem ? If yes, then why ? Context is being restored automatically either through the shadow registers for High Priority or through your program if LP is used.
    Context/Shadow registers will ensure that when it returns from the interrupt ... those 3 register sets will have the same contents in them.
    But if values get written to the wrong BANK somewhere within the ISR, shadow registers can't help.
    It's especially important to maintain the proper PREV_BANK when using ASM in the Main program, since there are no Shadow registers to get everything back to normal when it's finished.
    And ALL ASM routines in the Main program that use any PBP macros like CHK?RP, RST?RP, MOVE?xx with other bank switching methods, should end with ...
    ; for 16F's ...
      clrf  STATUS
    PREV_BANK = 0
    ; for 18F's
      clrf BSR
    PREV_BANK = 0
    Which resets PBP's banking system in preparation for the next statement.
    Sougata,
    Just curious, are you using PBP 2.6 ?
  1. Quadrature encoder and ASM Interrupts. questions..
    By godfodder in forum mel PIC BASIC Pro
    Last Post: - 17th March 2013, 14:45
  2. first project, and yes, doesn`t work
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 06:13
  3. Migrating from PIC16F690 to PIC18F4525 and having LCD issues
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 6th June 2008, 20:05
  5. 4 Bit Lcd Hookup
    By GEEZER in forum mel PIC BASIC Pro
    Last Post: - 11th May 2005, 00:14
