4 Bit LCD issue with interrupts
Results 1 to 16 of 16
    Feb 2005
    Kolkata-India
    Default Yes
    Yes, I am frustrated.
    Sougata
    If enabling Interrupts is causing the LCD to misbehave then...
    Is outputing to the LCD actually causing an interrupt?... ie have you connected the LCD to a pin that might itself be triggering an interrupt, and check your PIC that your LCD connections have not been bridged across to an adjacent pin that might be triggering an interrupt.
    Try to enable interrupts one by one to see which one (or which ones) are causing the problem. This might give you a clue where to look further.
  1. Quadrature encoder and ASM Interrupts. questions..
    By godfodder in forum mel PIC BASIC Pro
    Last Post: - 17th March 2013, 15:45
  2. first project, and yes, doesn`t work
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 07:13
  3. Migrating from PIC16F690 to PIC18F4525 and having LCD issues
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 6th June 2008, 21:05
  5. 4 Bit Lcd Hookup
    By GEEZER in forum mel PIC BASIC Pro
    Last Post: - 11th May 2005, 01:14
