first project, and yes, doesn`t work
Results 1 to 16 of 16
    Default first project, and yes, doesn`t work
    I try to build a box for cigarettes.
    Parts:
    -pic16F913
    -mclr reset
    -ext int (using DT interrups)
    -dumb LCD
    -h-bridge+latching solenoid
    Unfortunately the LCD show me just "999"...and even the ext interrupts doesn`t work
    If you guys have a minute just take a look...see the attachments
    Thank you
     @        __config _INTOSCIO & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _BOD_OFF & _IESO_OFF  & _FCMEN_OFF & _CP_OFF & _CPD_OFF
    CLEAR       'Clear all ram registers
    'MCU CLOCK SOURCE
    OSCCON.0 = 0       'int osc is used for sys clock (SCS bit)
    OSCCON.6 = 0       'int osc freq 32kHz (IRCF bits)
    OSCCON.5 = 0
    OSCCON.4 = 0
    'PORTS CONFIG
    ANSEL=0                  'Analog to Digital converter disabled
    TRISA = %10000000  'PORTA.7 (T1OSI=XTAL) to inputs
    TRISB = %00000001  'PORTB.0 (=external interrupts) to input
    TRISC = %00000111  'PORTC.2 to 0 (=1/3 BIAS for LCD) to inputs
    ''Timer1 CONFIGURATION (part of)
    T1CON.1 = 1           'clock for Timer1 is ext (TMR1CS bit)
    T1CON.2 = 1           'do not sync with the int clock (T1SYNC bit)
    T1CON.3 = 1           'LP oscillator is enabled for Timer1 clock (when INTOSC without CLKO is active) (T1OSCEN bit)
    'LCD CONFIGURATION
    LCDCON.4 = 1         'enable bias voltage pins (VLCDEN bit)
    LCDCON.3 = 1         'clock source LFINTOSC (31kHz/32) (CS bits)
    'LCDCON.2 = ?
    LCDCON.0 = 1        '1/4 multiplex (all COM used) (LMUX bits)
    LCDCON.1 = 1
    LCDPS.7 = 0         'waveform type-A (WFT bit)
    LCDPS.6 = 0         'bias mode (when LMUX=11) (BIASMD bit)
    LCDPS.3 = 0         '1:16 prescaler (31kHz/32/8=121Hz) (LP bits)
    LCDPS.2 = 1
    LCDPS.1 = 1
    LCDPS.0 = 1
    LCDSE0.3 = 1       'enable SEG3,4,5,6,8,9 (SE bits)
    LCDSE0.4 = 1
    LCDSE0.5 = 1
    LCDSE0.6 = 1
    LCDSE1.0 = 1
    LCDSE1.1 = 1
    'Clear??? LCDDATA registers see AN1070
    LCDCON.6 = 0     'enable the LCD in SLEEP mode (SLPEN bit)
    'PIR2.4 = 0         '(why ???) clear LCD Interrupt Flag (LCDIF bit)
    'VARIABILES
    adr4tmr1LO VAR BYTE     'RAM adr for startup timer1_LOW _BYTE value
    adr4tmr1HI VAR BYTE     'for timer1_HIGH _BYTE value
    T1 VAR WORD        'temp var for TMR1 startup value
    nc var word
    nc0 var word	'number of cigarettes (index) at address 0+1
    nc2 var word	'at adr 2+3
    nc4 var word	'at adr 4+5
    LCD VAR WORD           'number on LCD
    hundreds VAR BYTE     'temporary LCD var
    tens var byte             'temp LCD var
    ones var byte             'temp LCD var
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    INT_LIST  macro
         INT_Handler    INT_INT,  _open_battery_cover,   PBP,  yes
        INT_CREATE
        INT_ENABLE   INT_INT
    'WRITE TO EEPROM the startup timer1 values DIVIDED by 4 to fit into the 14 bytes (Timer1_startup_value/4)
    DATA @48,WORD 12773,WORD 12927,WORD 13080,WORD 13234,WORD 13388,WORD 13541,WORD 13695,WORD 13848
    '...not completed...more then 10k characters to upload
    'LATCH THE BOX
    lock_the_box:
    PORTB.1 = 1       'armature out
    PAUSE 1
    PORTB.1 = 0
    'GET THE CIGARETTE INDEX
    Interval_Tigari:
    READ 0, NC0.LowByte    'read the last cigarette index from EEPROM_location 1
    READ 1, NC0.HighByte    'from EEPROM_location 1
    READ 2, NC2.LowByte    'from EEPROM_location 2
    READ 3, NC2.HighByte    'from EEPROM_location 2
    READ 4, NC4.LowByte    'from EEPROM_location 3
    READ 5, NC4.HighByte    'from EEPROM_location 3
    'IF power down at writing between (nc0.LowByte and nc0.HighByte) or (nc0 and nc2)
    if nc4-nc2=0 then
        IF nc2-nc0<>0 THEN
            nc=nc2+1
            goto next_cigarette
    'IF power down at writing between (nc2.LowByte and nc2.HighByte)
    if nc4-nc2<>0 THEN
        IF nc2-nc0<>0 then
            nc=nc4+1
            goto next_cigarette
    'IF power down (or not) at writing anywere else
    nc=nc0
    next_cigarette:
    if nc = 16383 then         'EEPROM is just 14 bytes
        goto get_adr4tmr1
    NC = NC+1       'next cigarette
    'GET START RAM ADDRESS RANGE FOR TIMER1 STARTUP VALUE BY CIGARETTE INDEX
    get_adr4tmr1:
    SELECT CASE nc
        Case Is < 141       '1st week
            adr4tmr1lo=48
        Case Is < 255       '2nd week
            adr4tmr1lo=64
        Case Is < 349       '3rd week
            adr4tmr1lo=80
        Case Is < 430       '4th week
            adr4tmr1lo=96
        Case Is < 500       '5th week
            adr4tmr1lo=112
        Case Is < 563       '6th week
            adr4tmr1lo=128
        Case Is < 619       '7th week
            adr4tmr1lo=144
        Case Is < 670       '8th week
            adr4tmr1lo=160
        Case Is < 717       '9th week
            adr4tmr1lo=176
        Case Is < 760       '10th week
            adr4tmr1lo=192
        Case Is < 800       '11th week
            adr4tmr1lo=208
        Case Is < 837       '12th week
            adr4tmr1lo=224
        Case Is >=837       '13th week and more
            adr4tmr1lo=240
    END SELECT
    'COUNTDOWN LCD
    Countdown:
    LCDCON.7 = 1      'enable the LCD module (LCDEN bit)
    for hundreds = 9 to 0 step -1
        LOOKUP hundreds,[1,0,1,1,0,1,1,1,1,1],LCDDATA10.1
        'hundreds seg A (0 to 9)
        for tens = 9 to 0 step -1
            LOOKUP TENS,[1,0,1,1,0,1,1,1,1,1],LCDDATA9.3
            'tens seg A (0 to 9)
            for ones = 9 to 0 step -1
                LOOKUP ones,[1,0,1,1,0,1,1,1,1,1],LCDDATA9.5 'ones seg A (0 to 9)
                LCD=hundreds*100+TENS*10+ONES
    'GET START RAM ADDRESS FOR TIMER1 STARTUP VALUE BY LCD VALUE
                    IF LCD<=999 THEN
                        IF LCD>=875 THEN
                           goto Start_Timer1_interrupt
                    IF LCD<=874 THEN
                        IF LCD>=750 THEN
                            adr4tmr1lo = adr4tmr1lo+2
                    IF LCD<=749 THEN
                        IF LCD>=625 THEN
                            adr4tmr1lo = adr4tmr1lo+4
                    IF LCD<=624 THEN
                        IF LCD>=500 THEN
                            adr4tmr1lo = adr4tmr1lo+6
                    IF LCD<=499 THEN
                        IF LCD>=375 THEN
                            adr4tmr1lo = adr4tmr1lo+8
                    IF LCD<=374 THEN
                        IF LCD>=250 THEN
                            adr4tmr1lo = adr4tmr1lo+10
                    IF LCD<=249 THEN
                        IF LCD>=125 THEN
                            adr4tmr1lo = adr4tmr1lo+12
                    IF LCD<=124 THEN
                            adr4tmr1lo = adr4tmr1lo+14
    Start_Timer1_Interrupt:
                    READ adr4tmr1lo,T1.LowByte     'Timer1_startup_value/4
                    adr4tmr1HI=adr4tmr1lo+1
                    READ adr4tmr1HI,T1.HighByte
                    T1 = T1*4          'Timer1 REAL startup value
                    TMR1H = T1.HighByte
                    TMR1L = T1.LowByte
                    T1CON.0 = 1      'enable Timer1 (TMR1ON bit)
                    T1CON.5 = 1      'Timer1 input clock prescale (1:8) (T1CKPS bits)
                    T1CON.4 = 1
                    T1CON.6 = 1      'enable Timer1 Gate (T1GE bit)
                    T1CON.7 = 0      'Timer1 Gate is not inverted (T1GWN bit)
                    PIE1.0 = 1         'enable overflow int (TMR1IE bit)
                    INTCON.6 = 1     'enable all unmasked peripheral int (PEIE bit)
                    INTCON.7 = 1     'enable global int (GIE bit)
    @ sleep
    @ nop
    @ nop
                    PIR1.0 = 0         'clear Timer1 int flag (TMR1IF bit)
                    PIE1.0 = 0         'disable overflow int (TMR1IE bit)
                    T1CON.0 = 0      'disable Timer1 (TMR1ON bit)
            next ones
        next tens
    next hundreds
    'UNLOCK THE BOX
    unlock_the_box:
    WHILE PORTB.0 = 1
    'write to lcd OCE "open cover error"
    WEND
    PORTA.0 = 1                                 'armature in
    PAUSE 1
    PORTA.0 = 0
    'write the same "nc" value at three locations to fix the power down issue at the writing time
    WRITE 1, NC.HighByte      'write to RAM the "nc" LOW BYTE
    WRITE 0, NC.LowByte      'the "nc" HIGH BYTE
    WRITE 3, NC.HighByte
    WRITE 2, NC.LowByte
    WRITE 5, NC.HighByte
    WRITE 4, NC.LowByte
    'turn off the LCD
    LCDCON.4 = 0    'disable bias voltage pins (VLCDEN bit)
    LCDCON.6 = 1    'disable the LCD in SLEEP mode (SLPEN bit)
    LCDCON.7 = 0    'disable the LCD module (LCDEN bit)
    END                 'wait for MCLR reset
    'INTERRUPT WHEN THE BATTERY COVER IS OPEN
    open_battery_cover:
    PAUSE 1
    PORTB.1 = 0
    @ INT_RETURN
    Attachment 3357
    Attachment 3358
    Default the attachements
    oops
    Name:  the box_logic.JPG
    Name:  the box_circuit1.JPG
    Question the XTAL doesn't oscillate
    i add one LED to PORTA.1 and i tryed to blink it using external osc
    @        __config _LP_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _BOD_OFF & _IESO_OFF  & _FCMEN_OFF & _CP_OFF & _CPD_OFF
    CLEAR                       'Set all ram registers to zero
    'MCU CLOCK SOURCE
    OSCCON.0 = 0                'EXTERNAL osc is used for sys clock (SCS bit)
    'PORTS CONFIGURATION
    ANSEL=0
    TRISB = %00000000
    TRISC = %00000000
    PORTA=%00000000
    PORTB=%00000000
    PORTC=%00000000
    blink_LED:
    PORTA.1 = 1
    PAUSE 1
    PORTA.1 = 0
    GOTO blink_LED
    what i`m doing wrong ?
    Best regards,
    Bogdan
    Hello bogdan,
    Had to hunt for the data sheet . . . This chip has comparators on PortA and to use as digital output you have to turn them off with
     CMCON0 = 7.
    I have not studied it any farther yet.
    EDIT: if you are not using this chip to drive a discrete LCD ( one without a controller built in ) disable the LCD control module. I think this will do that for you:
     LCDCON = %0100000  ' section 10.1 datasheet
    Doh! I see you are using it in the first code posted
    First of all, I would like to thank you for your reply
    I've tried with CMCON0 = 7...no luck
    By the internal osc is blinking (even with the comparators off)
    Do you think i should change the values of the caps next to the crystal (22p) ? (....i already tried another crystal and i have the same results)
    Thank you
    Apr 2009
    Boise, Id
    Hello, I don't know if this has anything to do with your trouble, but I was using DT interupts and changed the T1CON settings. The changes I made messed with the configureations Darrel made in the include file. My post was a few days ago "DT Interrupt and Elapsed Time Running Slow ". It might give you a clue. I'm new at this myself, but that's what my problem was.
    Shane
    Default no blinking
    Hi Shane....i will like to get to the "T1CON settings" part...but, right now i coudn't even make one stupid LED to blink by the external osc (i`m sure i missing something with the ext osc configuration)
    I saw in your post (DT Interrupt and Elapsed Time Running Slow) you use internal 8 MHz OSC....what about if you want to use ext osc...how you will change the T1CON settings ?
    Thank you for the heads up
    Bogdan, this code you wrote isn't too hot...
    blink_LED:
    PORTA.1 = 1
    PAUSE 1
    PORTA.1 = 0
    GOTO blink_LED
    You're turning your LED on for 1mS and then IMMEDIATELY turning it off again... so your eye will probably see your LED ON all the time, but certainly my eye can't catch a blink where the ON state is 1mS and the OFF state is a couple of uS.
    Correct that to something like...
    blink_LED:
    PORTA.1 = 1
    PAUSE 250
    PORTA.1 = 0
    PAUSE 250
    GOTO blink_LED
    Also, another mistake you made, you want PORTA.7 to be an INPUT, by stating PORTA=%00000000 you're forcing it to be an OUTPUT, delete that line.
    Apr 2009
    Boise, Id
    Another thing I have a question on, you are using a 32khz crystal. I believe PBP defaults to 4 mhz unless something is Defined for OSC speed.
    DEFINE OSC 8
    for 8Mhz clock.
    Without that I don't know if PBP would know what to do?
    I don't know that 32 khz can be defined in PBP? Some one else that knows more than me might have some better input?
    Shane
    Quote Originally Posted by bogdan View Post
    ...but, right now i couldn't even make one stupid LED to blink by the external osc (i`m sure i missing something with the ext osc configuration)
    External Oscillator ? Are you using an external oscillator ? Or are you using a crystal and caps , or a 3 pin resonator ? I ask, because you mentioned the caps. . . and a crystal with caps / or 3 pin resonator will use a different setting in the config statement from an external oscillator.
    EDIT: OK I looked closer at your code and schematic, I think your config should be :
    The data sheet indicates to use LP_OSC for 32khz
    Shane: Osc set by oscon register
    Apr 2009
    Boise, Id
    Joe S.
    So from the data sheet:
    "LP Oscillator mode selects the lowest gain setting of the
    internal inverter-amplifier. LP mode current consumption
    is the least of the three modes. This mode is designed to
    drive only 32.768 kHz tuning-fork type crystals (watch
    crystals)."
    The OSCON and Config is setting to LP. I was under the impression that PBP needed a "DEFINE OSC" so it know's what speed things are running at?
    Is that not the case?
    Bogdan: Another thing you might try is using the interal OSC for testing, at least to get a light to blink so you know the Pic is working.
    Shane
    Quote Originally Posted by ShaneMichael View Post
    Joe S.
    crystals)."
    Shane
    Honestly Shane, I do not know for sure.
    As I understand it the define is used to synchronize PBP's timing with the assembler's, but I think it only accepts Integer numbers and then only certain ones. A Good question for the EXPERTS. I will have to read up on this . . .
    Default start from zero,... again
    I really appreciate your help guys.
    Melanie: ...i know, the code wasn't hot at all, you right, the second PAUSE xxx should be there (i miss that), ... about the PORTA=%00000000 you're forcing it to be an OUTPUT i didn' know...Thank You
    Shane: ... i tried to blink it by the internal oscillator and is working, but by the ext crystal (32khz) still doesn'work
    Joe: ...i don't think i have to use DEFINE, because i already setup the fuse @ __config _LP_OSC
    Please let post first the schematic and the code and after that take a look at my questions (please):
    schematic:
    code:
    'MCU CLOCK SOURCE
    ANSEL=0
    TRISA = %10000000 'set PORTA.7 (T1OSI=XTAL) to input
    TRISB = %00000000
    TRISC = %00000000
    PORTB=%00000000
    PORTC=$00000000
    PORTB.6 = 1 'JUST FOR TEST
    blink_LED:
    PORTA.1 = 1
    PAUSE 250
    PORTA.1 = 0
    PAUSE 250
    GOTO blink_LED
    Default the questions
    1 -it will be enough to setup the fuse @ __config _LP_OSC and to setup the programmer (melabs U2 Programmer ) to update by itself the "Configuration From File" ?....or i have to comment the *.inc file also?
    2A -how should i setup the TRISA.6 and TRISA.7 when the external crystal is used for sys clock
    2B -what about if i will use internal osc (INTOSCIO) for sys clock and the external crystal for Timer1 ?
    3 -in the datasheet they say :"LP Oscillator mode selects the lowest gain setting of the internal inverter-amplifier. LP mode current consumption
    is the least of the three modes. This mode is best suited to drive resonators with a low drive level specification, for example, tuning fork type crystals."
    ...they say "A series resistor (RS) may be required for quartz crystals with low drive level."
    .... so do you think i should add one resistor there ?
    I saw the study case for pic16f690 and ext crystal ([HTML]http://ww1.microchip.com/downloads/en/AppNotes/91097A.pdf[/HTML])... should i go so deep ?
    I have alot more questions, but tomorrow i have to go to work guys.
    Thank You again for your patience.
    That was Shane . . .
    DEFINE OSC 8
    for 8Mhz clock.
    Shane
    Apr 2009
    Boise, Id
    Do they make a data sheet for dummies? I could use one. So reading the data sheet I noticed this statement:
    "6.4 Timer1 Oscillator
    A low-power 32.768 kHz crystal oscillator is built-in
    between pins OSC1 (input) and OSC2 (amplifier
    output). The oscillator is enabled by setting the
    T1OSCEN control bit of the T1CON register. The
    oscillator will continue to run during Sleep.
    The Timer1 oscillator is shared with the system LP
    oscillator. Thus, Timer1 can use this mode only when
    the primary system clock is derived from the internal
    oscillator or when the oscillator is in the LP mode. The
    user must provide a software time delay to ensure
    proper oscillator start-up."
    So by that statement I believe you want to use the internal OSC, I'd use it at 4 or 8 mhz.
    Timer one you would use the external crystal and set T1OSCEN =0 so you don't turn on the interal 32.768 crystal....I think? Like I said, I need a data sheet for dummies...
    I'd take on one thing at a time, get the pic working on the internal clock first. When you have a good handle on that then take on clocking Timer one from the crystal. Then as it breaks, you'll know what setting did it.
    Also, if it has an internal crystal at 32.768 khz, why use an external, is it just an accuracy concern?
    I don't think you'll need to dig any deeper than you already are, it's just a matter of getting the correct settings.
    Good Luck,
    Shane
