PICKit2 - warning about configuration words
Results 1 to 27 of 27
    The missing CONFIG words are because the 16F88 has two CONFIG words.
    When using PM, DEVICE sets CONFIG1 and DEVICE2 sets CONFIG2.
    @ DEVICE  HS_OSC, WDT_OFF, PWRT_ON ; etc
    @ DEVICE2 FCMEN_OFF, IESO_OFF
    Quote Originally Posted by botsmaker
    I too sometimes have a problem with pickit2 recognizing the 16f88. It will state that the device is unsupported.
    Hmmm, that's odd.
    No idea for that one.
    botsmaker, and others... Have any of you out there updated the OS for the pickit2? I havent had any problems with it programming 16F88 or any other pic's...
    Nov 2008
    Default pickit2 warning
    Just updated application software to 2.61 and updated OS to 2.32. I get the same response. It will recon the device when I connect it, then when I load the hex file I get the warning. "Device Error-hex file not loaded", "Unsupported part". I'm using micro studio and PBP.
    Nov 2008
    Default Warning Message
    This is the warning message I get from pickit2
    Nov 2008
    Default Use mplabfor 16f88
    I gave up trying to program the 16f88 with the pickit2 application program. Just use the mplab ide and select pickit2 as the programmer. I was able to program the 16f88 just fine with MPLAB. I used the same ic in both cases, so the ic is ok. I don't know what the problem is, but I need to get back to work.
    Quote Originally Posted by botsmaker View Post
    I have gotten that error too, and when it does so it usually sets code protection too!
    The fine print in the pickit2 docs say to reselect the chip ( select another pic and then reselect the one you are using) and then write the chip without selecting a hex, then select your hex and write.
    Nov 2008
    Default Pickit2 programs now
    I went back to using the pickit2 with the 16f88 and now it will program. Still get a "hex file not loaded error", but at the end of programming I get the green box.
    The problem is intermittent. I got less failure when running power of the board instead of powering through the pickit2. In other words, it always programmed.
    I did manage to build my own 4 digit meter with a 16f88 and PBP using some of the example code at MEL about driving led displays. This meter will display from 0 to 100.0 volts if you use a rail to rail opamp instead of the LT1077 I got in it now. Below are links to drawing and code.
    Hex
    Code
    Drawing
    Back when I was using a PIC Start I had to add a couple of capacitors across VDD-VSS or it would not program some of the 18Fs.
    Maybe a similar problem???
    SWITZERLAND (french speaking)
    Thumbs up That's it!
    Darrel,
    Where a hell did you find this information? Come on, tell us, you're working for the NSA or ex-KGB people, no?
    Anyway, thanks a lot!!!
    Roger
    It's explained in the PM assembler manual. PM.TXT.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Bruce knew where it was...
    I'd tell you, but then I'd have to kill you.
    Default maybe he's in the same gang as you
    Brrrrr!!!
    Some freezing sweat drops fall along my back. Okay then, I better never ever ask this question again
    NB: just a shame this info was not in some help file (MCS or PBP); would have been easier to find for me.
    Roger
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 09:54
  2. Warning: Some configuration words not in hex file
    Last Post: - 14th December 2009, 06:25
  3. 16F726 configuration
    Last Post: - 8th February 2009, 17:53
  4. running of page warning and error 16f877
    Last Post: - 7th November 2007, 01:05
  5. 16F630 OSCCAL value warning - PICKit2
    Last Post: - 3rd September 2007, 19:12
