PICKit2 - warning about configuration words
Results 1 to 27 of 27
    Nov 2008
    Default Pickit2 programs now
    I went back to using the pickit2 with the 16f88 and now it will program. Still get a "hex file not loaded error", but at the end of programming I get the green box.
    The problem is intermittent. I got less failure when running power of the board instead of powering through the pickit2. In other words, it always programmed.
    I did manage to build my own 4 digit meter with a 16f88 and PBP using some of the example code at MEL about driving led displays. This meter will display from 0 to 100.0 volts if you use a rail to rail opamp instead of the LT1077 I got in it now. Below are links to drawing and code.
    Hex
    Code
    Drawing
    Back when I was using a PIC Start I had to add a couple of capacitors across VDD-VSS or it would not program some of the 18Fs.
    Maybe a similar problem???
    Nov 2008
    Default Meter Photo
    I added a photo of the meter at my profile album. I designed a pcb to make up the circuit and had Expresspcb make it. The board can be configured into a frequency counter or event counter. Just load a different program for a new function. Its a multipurpose board. You can also bring out the ports through a 16 pin ribbon connector instead of a 4 digit display.
    Looks like a useful piece of work! I like the dual function idea.
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. Warning: Some configuration words not in hex file
    Last Post: - 14th December 2009, 07:25
  3. 16F726 configuration
    Last Post: - 8th February 2009, 18:53
  4. running of page warning and error 16f877
    Last Post: - 7th November 2007, 02:05
  5. 16F630 OSCCAL value warning - PICKit2
    Last Post: - 3rd September 2007, 20:12
