Presetting Configuration Fuses (PIC Defines) into your Program
+ Reply to Thread
Results 1 to 40 of 83
    Jul 2009
    Default Re:Help in setting internal clock on 18F1220 device
    Joe S. and Bruce
    Thanks for your valuable help. Sorry its been a while since I've been able to get back to this project. Here is the status. I have set the CONFIG1H fuse to
    _INTIO2_OSC_1H as Bruce suggested and OSCCON = %01110000.
    I set the ICD as a programmer. When I released the PIC from Reset it runs so slow I thought it was not working. Either I screwed up the OSCCON settings or there is something I am missing.
    OSCCON = %01110000 'Define the Osc to 8 MHz
    LED2 var PORTB.2 ' LED
    cntr var word
    FET var PORTA.0
    TRISA = %00000000 ' Set PORTA ports 0-4 to input, 5-7 Output
    TRISB = %00000000 ' Set PORTB to all output
    PORTB = %00000100 ' Clear PORTB
    PORTA = %00000000 ' Clear PORTA
    cntr = 0
    FET = 0
    led2 = 1
    led2 = 0
    ' cntr = cntr + 1
    ' if (cntr <= 2) then goto main
    ' FET = 1
    Stop
    Can anyone Help me.
    Quote Originally Posted by wbubel View Post
    You should compile NOT using ICD COMPILE, use the one which says compile, only use ICD compile to use the ICD, recompile with the COMPILE for stand alone use. Put a
    or whatever number is right in you code near the top. The PIC is probably running using the fail safe oscillator .
    Jul 2009
    This piece of code made it work
    DEFINE OSC 4 'Define the Osc to 8 MHz
    asm
    bsf OSCCON, SCS1 ; 1x = Internal Block
    bcf OSCCON, SCS0 ; 00 = Primary Oscillator (20Mhz?)
    bsf OSCCON, IRCF2 ; 111=8000 110=4000 101=2000
    bsf OSCCON, IRCF1 ; 100=1000 011=0500 010=0250
    bcf OSCCON, IRCF0 ; 001=0125 000=0032
    MSTABLE010 btfss OSCCON, IOFS
    bra MSTABLE010 ; wait until Oscillator is stable
    endasm
    Feb 2008
    Michigan, USA
    Default Subtle differences in config
    This doesn't directly apply to your situation this time, but I did run into a sneaky change the other day that took me a while to notice..
    I was trying to change the oscillator config on a 18F1320. I had been recently using 18F1330s and just assumed they would be the same since they were so close family wise. Bad assumption. Here are the two together.
    ;*  18F1330.INC                                                 *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2006 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 06/05/06                                        *
    ;*  Version   : 2.47                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
            LIST p = 18F1330, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "P18F1330.INC"  ; MPASM  Header
            __CONFIG    _CONFIG1H, _OSC_INTIO2_1H
           ; __CONFIG    _CONFIG1H, _OSC_XT_1H
            __CONFIG    _CONFIG4L, _XINST_OFF_4L
            NOLIST
            LIST
    EEPROM_START	EQU	0F00000h
    BLOCK_SIZE	EQU	8
    ;*  18F1320.INC                                                 *
    ;*  Version   : 2.47                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            NOLIST
            LIST
            LIST p = 18F1320, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "P18F1320.INC"  ; MPASM  Header
            __CONFIG    _CONFIG1H, _INTIO2_OSC_1H    ; this for INT OSC
        ;   __CONFIG    _CONFIG1H, _XT_OSC_1H	 ;was this for XT OSC
            __CONFIG    _CONFIG4L, _LVP_OFF_4L
            NOLIST
            LIST
    BLOCK_SIZE	EQU	8
    the commented out part was my addition, but notice the different syntax for the oscillator statement.
    Just hadn't run into that before.
    Bo
    Feb 2008
    Michigan, USA
    Default Can't find @MyConfig
    Hi all,
    I have tried to find where the @MyConfig references were without any success. Anyone have them bookmarked?
    I still don't have a good handle on changing these without tweaking the .inc files and I'm afraid that's going to bite me someday (even though I do leave the original lines REM'd).
    I have seen @MyConfig used, but don't know if there are any caveats.
    Bo
    Hi Bo,
    @__Config MyConfig was something Darrel came up with for me, so as to be able to put the config statements on several lines. This was so I could see them without having to scroll across some 100 or so places on the screen. I have MCS set up with large fonts as I have rather poor vision. You still have to comment out the default configs and place the correct configs in your code. It simply allows you to put them on multiple lines. Search for my posts and you will find examples of it's use. If you need examples I can post some Saturday after my new cable internet connection get's hooked up, until then I am not at home while in here.
    JS
    Omaha, Nebraska USA
    Okay, I've rummaged through the manual, looked at several old threads, and at the "include" files for the device (16F88). I've carefully read through Melanie's post on the subject http://www.picbasic.co.uk/forum/show...16&postcount=1
    Whatever occurs after @_config generates error 122 ("illegal opcode"). It also appears that _INTRC_IO doesn't want to fly. I'm using MPASM.
    Maybe I've not found the right thread yet.
    HELP!
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
  1. pic program crashing
    By comwarrior in forum General
    Last Post: - 8th July 2009, 17:33
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  3. Making Program Code Space your playground...
  4. size of program vs mem on pic
    By PICMAN in forum General
    Last Post: - 1st March 2005, 18:23
  5. Serial communication PIC to PIC help.
    Last Post: - 24th January 2005, 16:45
Members who have read this thread : 6
