Pic12f683 Cmcon0 = 7
Results 1 to 26 of 26
    Hello,
    Edited.
    INTCON = %10001000 'internal oscillator
    OSCCON = %01110000 ' 8mHz
    CMCON0 = 7 'Comparators off
    GPIO = %00000000 'outputs low
    TRISIO = %00010000 'GP4 as input
    ANSEL = %00111000 'AN3 analog
    'Define ADCIN parameters
    Define ADC_BITS 10 ' Set number of bits in result
    'Define CCP1_REG GPIO 'PWM Output on gpio
    'Define CCP1_BIT 2 'Bit 2
    ' Variables
    Posit var Word
    Speed var byte
    Pause 100
    Scan:
    ADCIN 3, Posit ' Read channel AN3 to Posit
    Speed = Posit/4
    HPWM 1,Speed,1000
    Pause 10
    Goto Scan
    OK, I'm still trying to understand this and use code, so I thought that I would revive this thread.
    Above, the code has "ANSEL = %00111000 'AN3 analog" To me it looks like AN4 and 5 are also made analog. Is this needed? if it is not needed, I should be able to use:
    ANSEL = %00001000  ' AN3 analog
    ~ Dave
    Quote Originally Posted by StoneColdFuzzy View Post
    ~ Dave
    For the 12F683 there is no AN4 and AN5, those bits control the data conversion clock. see the Data sheet page 33.
    OK, yes, I see that now. Are they to be set to 1 for this application? Where may I find more information in layman's terms to help me understand what that is?
    ~ Dave
    Nov 2008
    This may help you a bit. I've been playing with the 12F683.
    @	__CONFIG _INTOSCIO & _FCMEN_OFF & _IESO_OFF & _BOD_OFF & _BOD_OFF & _CP_OFF & _MCLRE_ON & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF
    DEFINE OSC 8           ' Internal 8MHz
    DEFINE ADC_BITS 8      ' 8-bit resolution
    DEFINE ADC_CLOCK 2     ' Set clock source to Frc/32
    DEFINE ADC_SAMPLEUS 50 ' Sample time in uS before A/D conversion is started
    ADCON0 = %00000001		'ADC enabled and right justified
    ANSEL = %00001000		'GPIO.0 and GPIO.1 analog input
    INTCON = 0				'INTERRUPTS off
    OSCCON = %01110000		'8 Mhz
    TRISIO = %111011		'GPIO2 output
    GPIO = %00010000 		' All outputs = 0 on boot
    astouffer, thank you.
    What's wrong when I can compile multiplication but not division? I get this error "macro div?ctb not found in macro file."
    This compiles OK:
    width = 510 * mon
    This will not compile:
    width = 510 / mon
    ~ Dave
    I've been playing with this code to change HPWM depending on a monitored voltage. The original code at the top of this thread works, but it's erratic.
    I've changed things around a bit to fit my needs and it runs a little bit better, but it's still erratic, probably due to refreshing the duty cycle all of the time. I'm looking for suggestions to make this run a little more smooth. Any suggestions?
    ~ Dave
    Mon var Word
    Width var byte
    Pause 100
        ADCIN 3, mon ' Read channel AN3 to Mon
        width = mon*1
        if width <= 2 then OneP
        if width > 2 then twoP
    OneP:
        hpwm 1,255,2000
    TwoP:
        hpwm 1,32,2000
    ~ Dave
    Mon var Word
    Width var byte
    Pause 100
        width = mon*1
    OneP:
        hpwm 1,255,2000
    TwoP:
        hpwm 1,32,2000
    Anyone?
    ~ Dave
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 07:31
  3. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  4. Working with indivividual bytes of an array
    By J_norrie in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2007, 19:16
  5. code conversion
    By saturnX in forum mel PIC BASIC
    Last Post: - 3rd October 2005, 17:17
