Pic12f683 Cmcon0 = 7
Results 1 to 26 of 26
Threaded View
  1. #3
    Quote Originally Posted by penelopepug View Post
    Hi! I just purchased some PIC12F683s and am having some problems. The simple program I wrote takes a 0 to 5V analog voltage from a 5k potentiometer and this adjusts HPWM. I have 0.1uF caps in place from VDD to VSS and another on the pot's wiper. At the moment, the HPWM drives an LED. Ultimately it will feed a mosfet that will control a small toy motor.
    Compiler - PisBasic Pro 2.47
    Using MicroCode Studio
    Pic - PIC12F683
    I get a syntax error on the line "CMCON0 = 7" which disables the comparators. Yes, I tried "0" and "O" and just "CMCON". As well, I am getting irratic behavoir from the HPWM where as I adjust the pot, the duty cycle jumps around irraticaly. I used an oscilloscope to verify the behavior.
    Any advice would be appreicated. The program is below;
    INTCON = %10001000 ‘internal oscillator
    OSCCON = %01110000 ‘ 8mHz
    CMCON0 = 7 'Comparators off
    GPIO = %00000000 'outputs low
    TRISIO = %00010000 'GP3 as input
    ANSEL = %00111000 'AN3 analog
    'Define ADCIN parameters
    Define ADC_BITS 10 ' Set number of bits in result
    Define CCP1_REG GPIO 'PWM Output on gpio
    Define CCP1_BIT 2 'Bit 2
    ‘ Variables
    Posit var Word
    Speed var byte
    Pause 100
    Scan:
    ADCIN 3, Posit ' Read channel AN3 to Posit
    Speed = Posit/4
    HPWM 1,Speed,1000
    Pause 10
    Goto Scan
    Hello,
    Without checking to see if this code works, and without reading for understanding, I did compile as presented below and it compiles. I found 3 things which prevented it from compiling. You used ` instead of ' on some of your comments and you defined
    which are already defined in the 12f683.bas file. I just commented them out.
    HTH
    JS
    Oh, BTW, a scratchy pot can do wild things when used here too, and Sayzer will never steer you wrong.
    INTCON = %10001000 'internal oscillator
    OSCCON = %01110000 ' 8mHz
    'Define CCP1_REG GPIO 'PWM Output on gpio
    'Define CCP1_BIT 2 'Bit 2
    ' Variables
    Posit var Word
    Speed var byte
    Pause 100
    Scan:
    Speed = Posit/4
    HPWM 1,Speed,1000
    Pause 10
    Goto Scan
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 07:31
  3. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  4. Working with indivividual bytes of an array
    By J_norrie in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2007, 19:16
  5. code conversion
    By saturnX in forum mel PIC BASIC
    Last Post: - 3rd October 2005, 17:17
