Storing data in Flash (Program) memory
Results 1 to 10 of 10
    May 2009
    Saint-Quentin-en-Yvelines, FRANCE
    Dear Darrel,
    Thank you again for your help
    I will try all this as soon as I dig into the SW. I am currently testing and validating the hardware.
    The data will be bytes, but don't be afraid, I will not type then one by one !
    They will come from already existing tables in text format. So a simple select, copy and paste to the source file will do the job.
    Best regards
    MikeBZH
    Quote Originally Posted by MikeBZH View Post
    Great! That'll make things easy.
    Just one more suggestion then ...
    Put the data in a separate .ASM file.
     ; make sure each line has an Even number of values.
      DB  0xA4,0x95,0xB5,0xAA,0xA5,0x49,0x55,0x56,0xAD,0x55,0x4A,0x56,0xB5,0xAA
      DB  0xAD,0x56,0xD6,0x48,0x49,0x5B,0x6A,0xB5,0x55,0x4A,0x4A,0xAD,0x6A,0xAA
      DB  0x94,0xAA,0xAA,0xB5,0x5A,0x54,0xAA,0xB5,0xAA,0xB5,0x55,0xAD,0x69,0x11
      DB  0x25,0xB6,0xB5,0x55,0x55,0x25,0x2A,0xDA,0xD5,0x4A,0x52,0xAA,0xAD,0x55
      DB  0x6A,0xA9,0x25,0x2A,0xD5,0x6A,0xAA,0x95,0x55,0xAD,0x55,0x55,0x55,0xAD
      DB  0x6D,0x44,0x12,0xAD,0xDA,0xAA,0xAA,0x52,0x55,0x5B,0x6A,0x94,0x94,0xAA
      DB  0xB5,0x5A,0xA9,0x52,0xAD,0x6B,0x55,0x55,0x55,0x5B,0x5B,0x50,0x82,0x5B
    PBP has a limit to the number of lines in an ASM block.
    That .ASM file can be included from the program by the assembler which doesn't have that limit.
    DataByte   VAR  BYTE
    Offset     VAR  LONG
    DataTable1 CON  EXT
    DataTable2 CON  EXT
    '-----[The DATA table]--------------------------------------------------------
    GOTO OverData             ; Make sure data doesn't try to execute
    DataTable1
        #include "MyData.ASM"
    EndTable1
    DataTable2
        #include "MyOtherData.ASM"
    EndTable2
    OverData:
    '-----[Retrieve from DATA table]----------------------------------------------
    Offset = 1
    ReadCODE  (DataTable1 + Offset), DataByte
    LCDOUT  $FE, 1, HEX2 DataByte," "
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Making Program Code Space your playground...
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
