high voltage high frequency H-Bridge
Results 1 to 7 of 7
    New Zealand
    Yah, most small high speed ferrite transformers fall over at about 300kHz, this is why I was going to first boost the voltage, convert to high voltage DC and switch it back into a square wave, I'm just not sure on how to switch it with both high voltage and high frequency. I'm pretty sure i'd be fine if it were one or the other but combined they make it much more difficult for my simple brain.
    It's for an experimental rf heating device.
    Default Scratching my head . . .
    Quote Originally Posted by George View Post
    Mmmmmm . . . 450v x .040 amp = 18W not going to heat very much with that . . . Why does it have to be a square wave ? Seems like a class c rf amp would do what you want if sinewave driven. . .
    New Zealand
    well - yah, it doesn't have to be much power, I was only wanting about 10W of heat at this stage. One of the most important things is it's able to be made cheaply and reliably. I't doesn't have to be a square wave, a square wave is just preferable as it's kind of like a higher duty cycle. I have thought about RF amps but cant seem to find any small cheap ones that can do that voltage.
    So yah - ideally i'd like to transistor (bipolar or FET) switch it but it's just getting the Gate/base voltage up there.
    thanks
    Most MF/HF Amps are designed to work into a 50 ohm load... so you're looking at a 4kW device to give you the voltage you want.
    40mA 450V at 1MHz is still 20W of anybody's money... easilly doable with a single 807 or 6146 valve... but the plate Transformer will set you back $100-$200.
    Look on eBay for old Heathkit AM Ham HF Transmitters (from memory they all had American Indian native names I think). Nobody plays with AM anymore since they discovered SSB goes further. Those old 'Boat-Anchors' go for a song... and are a goldmine of parts you just can't buy anymore.
    Oh... if you achieve it with a square-wave input, let me know... I want to set a stop watch to see how long it takes for the FCC (or NZ's equivallent) to break-down your door...
    Melanie,
    Quote" Nobody plays with AM anymore since they discovered SSB goes further."
    You should live in the US.... Much better audio....
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  4. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 21:35
  5. Serin and TMR0
    By capitano in forum mel PIC BASIC Pro
    Last Post: - 17th May 2006, 15:58
