Serin and TMR0
Results 1 to 7 of 7
Thread: Serin and TMR0
    capitano's Avatar
    capitano Guest
    Post Serin and TMR0
    It's possible use Serin command and TMR0 interrupt in the same program ?
    why not??? the only thing you have to care about IMO, is to disable interupts before using SERIN.
    capitano's Avatar
    capitano Guest
    Post Serin and TMR0
    My program must turn on 64 led connected to PIC with 4 mux 74HC154
    This is my program but it don't work fine, i try to disable interrupt but ...
    DEFINE OSC 4 'Definisco fre. osc. quarzo
    ' LIBRERIE
    Include "modedefs.bas"
    ' IMPOSTA PORTE
    TRISA = 0 ' Imposto la porta A come uscita
    TRISB =%10000000 ' Imposto la porta B come uscita
    OPTION_REG=%11010001
    PIE1=%00000000
    ADCON1=%00000111
    'VARIABILI
    TX var PORTB.6
    RX var PORTB.7
    Mode var PORTB.5
    EN1 VAR PORTA.0
    EN2 VAR PORTA.1
    EN3 VAR PORTA.2
    EN4 VAR PORTA.3
    x var byte ' Definizione variabile tipo byte
    k var byte
    j var byte
    led1 var byte
    led2 var byte
    stato var bit[64]
    pos var byte
    high EN1
    high EN2
    high EN3
    high EN4
    for k=0 to 63
    stato[k]=0
    next k
    INTCON = %11100000
    ON INTERRUPT GoTo interr
    'PROGRAMMA PRINCIPALE
    mainloop: 'label
    intcon.5=0
    SERIN RX,T9600,pos
    intcon.5=1
    stato[pos]=1 -----------------> Active led a position pos
    GoTo mainloop ' ritorna allla label iniziale
    'GESTIONE DI INTERRUPT
    Disable
    interr:
    'Interrupt TMR0 -------------->>>' Routine to scan all 64 led
    I can't interrupt it
    If INTCON.2=1 then
    for x=0 to 15
    if stato[x]=1 then
    portb.0=x.0[3]
    portb.1=x.0[2]
    portb.2=x.0[1]
    portb.3=x.0[0]
    low EN1
    high EN2
    high EN3
    high EN4
    pause 1
    next x
    high EN1
    high EN2
    high EN3
    high EN4
    for x=0 to 15
    j=x+16
    if stato[j]=1 then
    portb.0=x.0[3]
    portb.1=x.0[2]
    portb.2=x.0[1]
    portb.3=x.0[0]
    high EN1
    low EN2
    high EN3
    high EN4
    pause 1
    next x
    high EN1
    high EN2
    high EN3
    high EN4
    for x=0 to 15
    j=x+32
    if stato[j]=1 then
    portb.0=x.0[3]
    portb.1=x.0[2]
    portb.2=x.0[1]
    portb.3=x.0[0]
    high EN1
    high EN2
    low EN3
    high EN4
    pause 1
    next x
    high EN1
    high EN2
    high EN3
    high EN4
    for x=0 to 15
    j=x+48
    if stato[j]=1 then
    portb.0=x.0[3]
    portb.1=x.0[2]
    portb.2=x.0[1]
    portb.3=x.0[0]
    high EN1
    high EN2
    high EN3
    low EN4
    pause 1
    next x
    high EN1
    high EN2
    high EN3
    high EN4
    INTCON.2=0
    Resume
    Enable
    thank you in advance for your availability and excuse me for my english
    Christian
    Feb 2004
    Germany
    Christian,
    what does your schematic look like?
    regards
    Ralph
    Aug 2005
    Weifang, Shandong, CHINA
    Exclamation Interrupt with serin command
    I am using a PIC16F88 with external resonator of 4Mhz.
    4 leds connected to portb pins and they are flashing in random in time with the internal timer1 and interrupt.
    I have a 433mhz transmitter on another device sending :
    serout rfmod,baud,[qual, dataout] ' qual = 10 and dataout = 11
    I am not sure how to set the serin command on portb.3 to look for an interrupt of receiving this serial data, once received it should turn of a select led on the portb pin.
    Any ideas ? or help appreciated please.
    yaskolo's Avatar
    yaskolo Guest
    Default Timer0,pasue,serin :(
    i am using tmr0 interrupt in picbasic.
    when i use pause,pulsin or serin command interrupt is not work correctly. can you help me for this. how can i use interrupt correctly with serin and pause.
    or if i use asm interrupt code is it work ?.
    thanks
    Those statement you said must be terminated prior to jump to interrupt routines. Using loop of short PauseUs, Using internal USART, create your own PULSIN statement will help.
    Now it depend of your skill level. Usually i don't use PULSEIN, but i use an internal TIMER in counter mode (something like RA4 T0CKIN) with a PAUSE (or pause loop). Same for Usart. Sure that's a bit harder but save a huge amount of codespace. Maybe, i said maybe, Darrel's instant interupt may be of help but i'd never test them.
    Even in assembler, SERIN, PAUSE, PULSEIN, should be terminated prior to jump to an interrupt handler. IMHO so far...
  1. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 20:02
