Does MICROCODE support PIC16LF88?
Results 1 to 11 of 11
    SWITZERLAND (french speaking)
    Default Does MICROCODE support PIC16LF88?
    Hello,
    Does anyone know if MICROCODE does support (program) 16LF88 µc?
    I would need to use one of those because of their low VDD but can't find them in the device list.
    Roger
    Sep 2007
    USA, CA
    the low power "L" parts are programmed using the standard part number.
    Thank you.
    This is what I also assume.
    I just wonder why the device list in MICROCODE shows some "L" devices then.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=3280&stc=1&d=123795932 1">
    Roger
    California, USA
    Dunno about the 16LF88, but I've programmed 16LF727's with MCS and PICkit2, using the 16F727 setting and it seems to work fine.
    steve
    How old is your version of MicroCode Studio?
    The original versions had a PIC.INI file that listed the available PIC's. Then you had to manually add any that weren't in the list.
    Later versions search the PBP folder and populate the drop-down box with all the *.INC files it finds. That way it always has the correct list for whatever version of PBP you have.
    There are no .INC files specifically for LF parts. So I'm guessing you have a really old version of MCS.
    Along similar lines Does PBP work for RFPICs like RFPIC12F675KT-I/SS ?
    Quote Originally Posted by PBP - Current PICmicro® MCU support
    rfPIC12C509AF, rfPIC12C509AG: Limited support as base device PIC12C509A (more information) .
    rfPIC12C509AF, rfPIC12C509AG, rfPIC12F675F, rfPIC12F675H, rfPIC12F675K: Supported as base device PIC12F675
    The rfPIC's are like 2 separate chips in a single package.
    The rfPIC12F675F is a standard 12F675, with an ASK/FSK transmitter module in the same package. To send data from the 12F675, you have to actually use a PIN as output, and connect it to either the DATAask or DATAfsk of the same chip. If you want to turn the carrier on/off it takes another output pin from the 675, connected to the RFEN pin of the transmitter.
    There are no registers in the PIC half that have any control over the transmitter half.
    As far as PBP or MCS is concerned, it's just a 12F675.
    In theory MicroCode should update it's own PIC supported list, case not you may need to add it by yourself. PIC.INI file is the one to edit. You can even create aliases to specific PIC, you just need to copy the right INC file and rename it the same way you have define it in PIC.ini.
    Great, Thank You.
    Default let's try
    I'm going to try the LF version then.
    It is not a question of cost since they are almost the same price as standard PICs; I just don't want to store PICs I wouldn't be able to program.
    BTW, I use Microcode Studio version 3-0-0-5.
    Roger
    Thumbs up It does work
    So, I tried to program a "LF" device and it worked like a charm.
    Roger
  1. Replies: 3
    Last Post: - 1st July 2008, 21:07
  2. Microcode studio loader problem
    By woodygjw in forum General
    Last Post: - 10th September 2007, 01:18
  3. Microcode Studio MPLAB support
    By jbpaul in forum General
    Last Post: - 27th November 2006, 06:55
  4. Replies: 2
    Last Post: - 9th February 2006, 22:03
  5. How to used ICD of microcode studio
    Last Post: - 19th November 2005, 00:29
