PC keyboard to ASCII
Results 1 to 9 of 9
    interak's Avatar
    interak Guest
    Post PC keyboard to ASCII
    Hi I have recently finished writing some code in PICBASIC PRO which will read a PS/2 or AT keyboard and output 7-bit ASCII.
    I know that this is not new but I have searched the Internet for a complete PIC working package and could not find one. (if I could I would have used it).
    I have noticed that there are quite a few people who have asked for this code and I have also found notes to say it is a trivial matter to make a PC keyboard converter program with a PIC.
    It is probably easier in assembler because there is more time to read and shift data but I found that once all the keyboard functions are in the right order it works very well with PICBASIC.
    I have put the details here -
    http://www.interak.pwp.blueyonder.co.uk/PCtoASCII.htm
    Alan
    Well done Interak! Sure there's a lot of people who'll learn a lot from it.
    Welcome on the forum!
    Quote Originally Posted by interak View Post
    Alan
    Hi Alan,
    Welcome to the forum, and thank you for this nice Code Example. Since you posted in PDF format someone had to retype it (I did) and it is posted below with configs for MPASM. This is a project many have discussed but never really brought to fruition, I am sure many who come here will find it useful.
    '*  Name    : PCtoASCII.BAS                                     *
    '*  Author  : Alan Paton                                       *
    '*  Notice  : Copyright (c) 2009                                *
    '*  Date    : revised Jan 2009                                  *
    '*  Notes   :MPASM configs added by Joe S.                      *
    '*  http://www.interak.pwp.blueyonder.co.uk/PCtoASCII.htm       *
    @MyConfig = _HS_OSC  & _LVP_OFF & _WDT_OFF & _CP_OFF
    @MyConfig = MyConfig & _BODEN_OFF & _MCLRE_ON & _PWRTE_ON
    @ __CONFIG   MyConfig
    ;@ device    INTRC_OSC_NOCLKOUT ;use internal oscillator
    ; DEFINE OSC 4
    CMCON = 7
    DEFINE OSC 20
    PBIT VAR BYTE
    D    VAR BYTE[12]
    SC   VAR BYTE
    CNT  VAR BYTE
    J    VAR BYTE
    CLK  VAR PORTA.0
    DAT  VAR PORTA.1
    CL   VAR BYTE
    SH   VAR BYTE
    AC   VAR BYTE
    LN   VAR BYTE
    LB   VAR BYTE
    'initialise
    PAUSE 1000 ' wait for keyboard to start up
    TRISB = 0
    TrisA = 0
    SH = 0
    CNT = 0
    CL = 0
    GOTO SCAN
    START:
    IF SC=$12 OR SC = $59 THEN ' shift key up
        SH = 0                 ' reset shift
        IF SC = $14 THEN       ' control key up
        CNT = 0                ' reset control flag
    lb = 0                     'clear last-byte flag
    'Setup ports to read keyboard ******************
    ' ************ SCAN shifts serial scancode into SC *********
    SCAN:
        sc = 0                 ' clear scan code
        TrisA.1 = 1            ' set DAT to input
        TrisA.0 = 1            ' set CLK to input
    ' Wait for clock transistion
    LP1:                       ' make sure clock is high
        IF CLK = 0 THEN
        GOTO LP1
    LP2:
        IF CLK = 1 THEN        ' clock idles high
        GOTO LP2               ' wait for clock to go low
        'clock now low - Start bit of scan code
        FOR J = 0 TO 9         ' get scan code
    LP3:
        IF CLK = 0 THEN        ' make sure clock is high
        GOTO LP3
        D(J) = DAT              'read data bit
        NEXT J
     ' shift bits into variable SC
        FOR J = 7 TO 0 STEP -1  ' D(8) & D(9) are parity & stop bits
        SC = SC << 1            ' shift 1 place left
        SC = SC + D(J)          ' set bit 0 of SC LSB = 0 MSB = 7
        NEXT J
        TrisA.0 = 0             ' set CLK to output
        CLK = 0                 ' and hold it
        IF LB = 2 THEN          ' last byte of up - code - don't display
            GOTO START
            IF SC = $F0 THEN    ' Check for key-up code
            LB = 2              ' Set last byte flag
                GOTO SCAN
                IF SC = $12 OR SC = $59 THEN  ' left and right shift keys
                SH = $80                      ' Set shift flag
                    GOTO SCAN
                    IF SC = $58 THEN          ' Caps lock on
                        GOSUB CPLOCK
                        GOTO SCAN
                        IF SC = $E0 THEN      ' Extended keys
                            GOTO SCAN         ' Get next byte
                            IF SC = $14 THEN   ' Left control key (& right . . $EO $14 )
                                CNT = 2        ' Set flag
                                GOTO SCAN
              ' and into SCAN CODE to ACSII conversion
              ' **************** CONVERT TO ASCII CODE ***************************
              ' scan code in SC
            ASCII:
                IF SC = $5A THEN   'is it CR ?
                    AC = $0D
                    GOTO ASOUT     ' Yes send it
                    SC = SC + SH   'SH=$80 if shift key down (0 if not)
                    LN = $FF       ' Set List No. to high value
    ' convert to ASCII (codes from 20H to 7FH)
                    LOOKDOWN SC,[$29,$96,$9E,$5D,$A5,$BD,$52,$C6,$C5,$BE,$D5,_
            $41,$4E,$49,$4A,$45,$16,$1E,$26,$25,$2E,$36,$3D,$3E,$46,$CC,$4C,$C1,$55,_
            $C9,$CA,$D2,$9C,$B2,$A1,$A3,$A4,$AB,$B4,$B3,$C3,$BB,$C2,$CB,$BA,$B1,$C4,_
            $CD,$95,$AD,$9B,$AC,$BC,$AA,$9D,$A2,$B5,$9A,$54,$61,$5B,$B6,$CE,$A6,$1C,_
            $32,$21,$23,$24,$2B,$34,$33,$43,$3B,$42,$4B,$3A,$31,$44,$4D,$15,$2D,$1B,_
            $2C,$3C,$2A,$1D,$22,$35,$1A,$D4,$E1,$DB,$DD,$66],LN
        IF LN = $FF THEN    ' Scan code not found
            GOTO NUMPAD     ' Now check number pad
    'matching scan code has been found
        IF CNT = 2 THEN     'Is control key pressed ?
            AC = LN - $40   ' Get ASCII code
            GOTO ASOUT      ' Send it
    ' Caps Lock On - check for the following conditions
            IF LN>$40 AND LN<$5B THEN ' Caps lock on & (semi) colon selected
                AC = $3A              ' ASCII code for colon
                GOTO ASOUT
            GOTO AS2                  ' Send out to computer keyboard port
    ' Check number pad
    NUMPAD:
            LOOKDOWN SC,[$30,$31,$32,$33,$34,$35,$36,$37,$38,$39,$2A,$2D,$2B,$2E,$09,$1B],AC
            GOTO ASOUT
    AS2:
        AC = LN + $20                 ' Convert List No. to ASCII
    ASOUT:
          PortB.7 = 1                 ' Strobe - normally high - pulse low
          PAUSE 2
          PortB = AC                  ' Send ASCII code to Port B
          PAUSE 2                     ' Bit 7 (strobe) is zero
          PortB.7 = 1
          GOTO SCAN
    ' ********************* CAPS LOCK *********************************************
    CPLOCK:
         IF CL = 0 THEN               ' Toggle caps lock
            CL = 4                    ' 4 is Bit 2 0000 0100
            CL = 0
    original source code obtained from:
    Any Typing errors are all mine !
    Note: this program's author also generously provided the compiled hex code on the web site listed for those who do not own P Basic Pro compiler, making it useful to all. A heartfelt Thank You to you Alan. Your first post and it was to share something.
    May 2008
    Italy
    Alan, an additional welcome to the forum from my side, and thank you for the useful code you have shared.
    Al.
    I didn't see them, but I knew they were there.
    Here is the corrected code, Thank You again Alan !
    '*  Author  : [Alan Paton]                                      *
    '*  Date    : 2/17/2009                                         *
    @ __CONFIG   MyConfig
    ; DEFINE OSC 4
    CMCON = 7
    DEFINE OSC 20
    PBIT VAR BYTE
    D    VAR BYTE[12]
    SC   VAR BYTE
    CNT  VAR BYTE
    J    VAR BYTE
    CLK  VAR PORTA.0
    DAT  VAR PORTA.1
    CL   VAR BYTE
    SH   VAR BYTE
    AC   VAR BYTE
    LN   VAR BYTE
    LB   VAR BYTE
    'initialise
    TRISB = 0
    TrisA = 0
    SH = 0
    CNT = 0
    CL = 0
    GOTO SCAN
    START:
    SCAN:
        IF CLK = 0 THEN
        GOTO LP1
    LP2:
    LP3:
        GOTO LP3
        NEXT J
        NEXT J
            GOTO START
                GOTO SCAN
                    GOTO SCAN
                        GOSUB CPLOCK
                        GOTO SCAN
                                CNT = 2        ' Set flag
                                GOTO SCAN
              ' scan code in SC
            ASCII:
                    AC = $0D
    '  Matching scan code has been found
    '  CAPS LOCK ON - check for the following conditions
        IF LN>$40 AND LN<$5B THEN   '  caps lock on & lower case selected
            AC=LN
        GOTO ASOUT
        IF LN=$1B THEN        '  caps lock on & (semi)colon selected
            AC=$3A 'ASCII code for colon
        GOTO ASOUT
        GOTO AS2 'send out to computer keyboard port
    '  check number pad
    NUMPAD:
            GOTO ASOUT
    AS2:
    ASOUT:
          PAUSE 2
          pORTb.7 = 1
          GOTO SCAN
    CPLOCK:
            CL = 4                    ' 4 IS BIT 2 0000 0100
            CL = 0
    interak's Avatar
    interak Guest
    Post
    Hi Sorry Joe there is another bit not quite right. The PDF on the website definitely is OK because I printed it from the program listing.
    Just above the CAPS LOCK ON code should be......
    GOTO ASOUT 'send it
    '''''''''''''''''''''''''insert
    IF CL=0 THEN 'Caps Lock OFF
    GOTO AS2 '& matching code found
    'CAPS LOCK ON
    Dec 2008
    Los Angeles, CA
    Wink
    Wow! Thanks! I've been looking for some sample code, and it looks like you've got it!
    I did buy one of these (just to avoid the work and get my project done quickly), and must say that it works perfectly (if they only had a USB version!!) :
    http://www.multilabs.net/ezKEY.html
    interak's Avatar
    interak Guest
    Post
    Hi Thanks for your kind words, it's good to know that it could be useful.
    In case anyone noticed, I should mention that there is a few lines of the code which check if Caps Lock is on and if the colon/semicolon key has been pressed.
    This is required when using an old 8-bit CP/M computer as it allows for changing drives when working in Caps (i.e A: C: etc) - this is a typical function of ASCII keyboards.
    This code could be removed if it is not required.
    Alan
    interak's Avatar
    interak Guest
    Post
    Hi again I have just noticed that the typed-in code is not quite correct at that point - it should be.....
    'CAPS LOCK ON - check for the following conditions
    if LN>$40 and LN<$5B then 'caps lock on & lower case selected
    AC=LN
    goto ASOUT
    if LN=$1B then 'caps lock on & (semi)colon selected
    ac=$3A 'ASCII code for colon
    goto asout
    goto as2 'send out to computer keyboard port
    'check number pad
    Alan
  1. AT/PS2 Keybord - PIC Interface?
    By Kamikaze47 in forum Code Examples
    Last Post: - 9th August 2009, 16:10
  2. One USB keyboard to Two USB Ports
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 00:04
  3. PC Keyboard question
    By HatchetHand in forum mel PIC BASIC Pro
    Last Post: - 18th September 2007, 06:03
  4. Pic to PC AT keyboard caracters
    By sezgin05 in forum General
    Last Post: - 27th March 2007, 10:45
  5. Making a Keyboard Encoder
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 27th December 2006, 16:25
