I may have some time to investigate about Modcom... if I had the link for it
It's certainly not down to hardware but how PC software behave.
Thanks steve
Here is the link:
http://www.weedtech.com/modcom.zip
Hi all
I tried the following to exclude some hardware issue
Took another PC with another comport, just to be shure
On my Easypic4 board I checked that no additional Pull-up or down's are available
When I disconnect the MAX232 serial driver the initial state of RC6 = High,
RC7 = Low
When I reconnect the MAX232 RC6 and 7 becomes High
So all looking normal
Then when I measure with my scoop on RC7 with the terminal program running
(so the command RAD0 (cr) is working fine) I see no difference when I run
for example MODCOM
Can anyone try to use MODCOM with a simple program using a serial command
To see if it works at your end
Use HSERIN/HSEROUT 19200 8N1 and a hardware driver like the MAX232
Looking forward !!!
