You will find files in the MPASM Suite subdirectory of the Microchip directory on your C: something like P16f648A.inc . Open the one for the chip you are using (do not change anything here ) and you will find all the configuration fuse settings for that chip ( that MPASM USES ) PM will use the same fuses but may spell the names a little differently, and will likely use different syntax.
