Q: using MCLR for Input on 12F683
Results 1 to 40 of 47
    Thanks LinkMTech and Mackrackit:
    Both worked. FYI, I fly RC planes and have recently gained interest in the PIC stuff, mostly with the 12F683 due to its size. I'm learning this stuff...slowly (but wow, has it got potential!).
    I have a couple more questions hopefully you can help me with.
    1. having some issues simply running LED's on ports other than gpio.0 and 1. I'm not sure if I need to assign them, change them??? When trying, I see they have a faint glow???
    2. When using GPIO.4 and an input to store a pulsin value, the program works, but if I use GPIO.3 it doesn't. I can't figure that one out.
    Thanks again gents.
    John.
    Default Beware PULSOUT as a failsafe
    I crashed my RC aircraft using the PULSOUT command.
    PULSOUT is a 'toggle'. Whatever state the pin was in, it will flip for the duration specified in the PULSOUT command. That is bad news if your servo pin gets clobbered and you were expecting it to be low when you called the PULSOUT routine.
    To be safe, you MUST predefine the pin state before calling PULSOUT.
    e.g.
    LOW ServoPin
    PULSOUT ServoPin, 500
    will work every time.
    HTH
    Brian
    Quote Originally Posted by BrianT View Post
    e.g.
    LOW ServoPin
    HTH
    Brian
    Thanks Brian, I've got the pulsout working...actual pretty good now. Just some issues with getting gpio.2 and gpio.3 to simply operate LED's!
    My code is posted above.
    Cheers,
    John.
    Quote Originally Posted by johnnylynx View Post
    Thanks again gents.
    John.
    Can you post your code?
    Whoops, sorry about that!
    here's the code:
    oSCCON = %01100000 ' Ocs set to 4 MHz
    TRISIO = %00000000 ' Set all ports to outputs, in this example
    CMCON0 = 7 ' Analog comparators off
    ANSEL = 0 ' Analog select set to digital, pg 69 data
    ADCON0 = 0 ' A/D turned OFF, pg 68 of data
    input gpio.4
    inpulse VAR Word
    memory var word
    low gpio.4
    low gpio.3
    start:
    SEROUT 0, 2, [12]
    start2:
    PULSIN 1, 1, inpulse
    if inpulse<50 then
    read 5, memory
    serout 0,2,[12,17, "Activating",13,"Failsafe :", #memory*10]
    goto start2
    if gpio.4=1 then
    write 5, inpulse
    serout 0,2,[12,17,"Failsafe",13,"Stored :", #inpulse*10]
    high gpio.3
    low gpio.4
    low gpio.3
    SEROUT 0, 2, [17,22,#inpulse*10]
    PAUSE 20
    GOTO start
    OSCCON = %01100000 ' Ocs set to 4 MHz
    input gpio.4 '<font color=red> make input</font color>
    inpulse VAR Word
    memory var word
    low gpio.4 <font color = red> ' Now you make it an output</font color>
    low gpio.3
    start:
    SEROUT 0, 2, [12]
    start2:
    if inpulse<50 then
    read 5, memory
    goto start2
    if gpio.4=1 then '<font color=red> still an output, are you wanting an input?</font color>
    write 5, inpulse
    high gpio.3
    low gpio.4 '<font color=red> is and should be an output</font color>
    low gpio.3
    PAUSE 20
    GOTO start
    Thanks Joe,
    I didn't catch that, I'll make changes and see if that fixes the input problem.
    I still have the output issue though with GPIO.3, it doesn't want to run the LED.
    Any thoughts?
    John.
    Not sure but I think that pin is input only.
    I dunno John, I never use the High / Low convention, preferring to specify TRISIO AND GPIO instead because as I understand it , High/Low reads modify's and writes the whole port ( all the I/Os ) when you do.
  1. How to MCLR by code for 16F877
    By fbestepe in forum mel PIC BASIC Pro
    Last Post: - 26th November 2014, 01:51
  2. 12F683 - Pin1 not working
    Last Post: - 8th February 2014, 18:38
  3. 16f677a to 12f683
    Last Post: - 25th July 2007, 07:16
  4. What does this MCLR instruction mean?
    By bartman in forum General
    Last Post: - 30th November 2004, 01:32
  5. I/O pin and MCLR
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 15th July 2004, 11:52
