How to MCLR by code for 16F877
Results 1 to 12 of 12
    fbestepe's Avatar
    fbestepe Guest
    Default How to MCLR by code for 16F877
    Hi everybody,
    I would like to learn how could I make MCLR reset by picbasic code. I mean, during MCLR reset some processes occur like PC turns back to start address and some others, what are the process occured during MCLR reset exactly, and could I realize all these processes by code? That is because the device is away from me and it requires MCLR reset sometimes, so I thought that I could do it by code periodically, once in a specified period.
    Thanks for all,
    Firat
    There is no vector you can jump to or instruction to effect an MCLR Reset.
    You can cause the Watchdog Timer to time-out (if you've set it), but a watchDog Reset isn't the same.
    The easiest way is to cross-connect a spare PIC pin (the one adjacent to the MCLR pin is a good choice!)... since they all power up as INPUT by default, all you have to do is OUTPUT your chosen pin LOW. Don't forget to TRIS your chosen pin as INPUT (until it's needed) and if you choose RA0 (as the adjacent pin), don't forget to set it to Digital Mode.
    See the RESET sub-section of the "Special Features of the CPU" section in your PIC's Datasheet for details of the state of the internal registers of your PIC following any given Reset.
    Firat, Yes it is possible to effect an MCLR function from within your code. Paste these lines into your code where you want to effect the reset function. I use this code on an 16F876 and it works great. I use it after waking from sleep mode.
    Asm
    bcf PCLATH, 3
    bcf PCLATH, 4
    goto 0
    EndAsm
    Try it and let me know....
    fbestepe's Avatar
    fbestepe Guest
    Default to the repliers
    Thanks for the replies Melanie and Dave,
    I thought the solution that you explained, Melanie, but my hardware is completed and operating now. I do not want to touch the hardware so I have to solve this problem by code.
    I will try your recommendation, Dave, and will inform you about the result.
    Thanks again....
    Firat.
    Post
    Dave,
    The trick you posted will "restart" the program but it will NOT affect the internal registers like a true reset would. As long as you 're aware of this there is no problems doing so.
    /Ingvar
    Ingvar, I never rely on the default settings of the processor comming out of an MCLR of soft reset as I have seen some strange default conditions in the past. I always set the registers initially that I will use and those that can effect the outcome. I usually reset the states of variables during program execution on a time or number of loops basis as I have seen some funny results from ram storage in the past. I assume that others are doing the same.
    Apr 2010
    Default Re: How to MCLR by code for 16F877
    Asm
    bcf PCLATH, 3
    bcf PCLATH, 4
    goto 0
    EndAsm
    Thank you for sharing . Your post did help me. Thanks
    This thread predates my membership here by a year or two, and I had never seen it. Thanks Dave for this delicious tidbit and thanks to Vett58 for resurfacing it. BTW, it works a treat!
    Apr 2010
    Quote Originally Posted by Archangel View Post
    I am grateful to you and all moderators and members to have shared the vast knowledge by this remarkably useful and accurate forum. Thanks for all you do.
    The software reset is not a complete hardware reset. Keep that in mind, since some registers are not really reset as in a power cycle.
    also can use an output driving a Mosfet ( w/ a little cap between gate and ground ) that clamps the reset pin to gnd ...
    not very smart, but damn efficient !
    I'd do like Alain. Simple, few extra parts and reliable.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  3. Loop with two motor and 2 sensors
    Last Post: - 8th December 2008, 23:40
  4. Making Program Code Space your playground...
    Last Post: - 19th July 2008, 08:26
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
