Old and beyond help ?
Results 1 to 40 of 47
    Dec 2007
    Northants England
    Thanks for that.
    My original circuit had three octal darlingtons (ULN 2803) with inputs directly coupled to Ports A, C and D I have also connected leds with 680ohms to each pin so that I can see what the ports outputs are. A test program switched on and off each led in turn thru ports D C and A in that order and worked OK. Problem arose when tryin to switch on all of the A port bits and leave them on. I have now disconnected ther darlington from port a and written the following simple test program:
    @ DEVICE pic16f887,intrc_osc_noclkout
    PORTD = 0
    PORTA = 0
    PORTC = 0
    TRISD = 0
    TRISA = 0
    TRISC = 0
     portA.0 = 1
     porta.1 = 1
     porta.2 =1
     porta.3 = 1
     porta.4 = 1
     porta.5 = 1
     porta.6 = 1
     porta.7 = 1
    I have just run this program and
    1. When Microcode studio fired up the Pickit2 the voltage Vdd had been set down to 3.3
    2. I turned up Vdd to 5 volts and programmed the chip.
    LEDs 0,1,2,3 tuswitched on and then off after the delay. LED 4 switched on and stayed on, LED 5 switched on and then off again after the delay and then LEDs 6 and seven switched on and remainedon. I can see no logic inthis although I have that horrible feeling that it is staring me in the face !
    Quote Originally Posted by DavidFMarks View Post
    Thanks for that.
    PORTD = 0
    PORTA = 0
    PORTC = 0
    TRISD = 0
    TRISA = 0
    TRISC = 0
     portA.0 = 1
     porta.1 = 1
     porta.2 =1
     porta.3 = 1
     porta.4 = 1
     porta.5 = 1
     porta.6 = 1
     porta.7 = 1
    If this is all of the code, then You have to turn off all the analog stuff to get it to work, ADCON, ANSEL, and Comparators
    Dec 2007
    Northants England
    Very many thanks. I now have the system fully operational and can start programming the Star of David which should now be appearing in the village tomorrow evening. It might not seem much but by this time tomorrow I confidently expect the village will be swarming with wise men and shepherds. Thanks again folks !
    Lets see some pictures
    . . .It might not seem much but by this time tomorrow I confidently expect the village will be swarming with wise men and shepherds. . . !
    You obviously do not live in Washington DC.
    Dec 2007
    Northants England
    Spoke too soon !... Not about the shepherds and wise men but about the program working. I have been programming a whole load of different sequences one after another. They have all worked ok until the last few, the program simply ignores them and returns to the beginning. If i bung in a goto directly to the last few sequences the behave erratically (cutting short loops etc. I wonder if I have broken some rule about memory size or borders or some such as I am far from clear on this subject .... To hell with the shepherds I just need the wise men.....
    We might be able to help if we could see your code.
    Dec 2007
    Northants England
    OK Just didn't want to clutter up the forum with my lengthy and probably badly written code, but here goes !
    '***********CHRISTMAS STAR PROGRAM FOR OPERATING  *************
    '**********A 16 ARM STAR WITH 8 LEDS ON EACH ARM  *************
    '******ARMS CONNECTED TO PORTS A AND C  AND EACH "RING"  ******
    '***************CONNECTED TO A PIN OF PORT D ******************
    '************AUTHOR DAVID MARKS DEC 2008 ***********************8
    ansel = %00000000
    delay var word
    fastflash var word
    PORTD = 0
    PORTA = 0
    PORTC = 0
    TRISD = 0
    TRISA = 0
    TRISC = 0
    fastflash = 150
    Ring0 var portd.0
    Ring1 var portd.1
    Ring2 var portd.2
    Ring3 var portd.3
    Ring4 var portd.4
    Ring5 var portd.5
    Ring6 var portd.6
    Ring7 var portd.7
    Arm0 var Portc.0
    Arm1 var Portc.1
    Arm2 var Portc.2
    Arm3 var Portc.3
    Arm4 var Portc.4
    Arm5 var Portc.5
    Arm6 var Portc.6
    Arm7  var Portc.7
    Arm8   var Porta.0
    Arm9   var Porta.1
    Arm10  var Porta.2
    Arm11  var Porta.3
    Arm12  var Porta.4
    Arm13  var Porta.5
    Arm14  var Porta.6
    Arm15  var Porta.7
    loop
      'EXPANDING WHITE CIRCLES
     For delay = 400 to 0 step -25
     high Arm0
     high Arm2
     high Arm4
     high Arm6
     high Arm8
     high Arm10
     high Arm12
     high Arm14
    High Ring0
    pause delay
    Low ring0
    High Ring1
    pause delay
    Low ring1
    High Ring2
    pause delay
    Low Ring2
    High Ring3
    pause delay
    Low ring3
    High Ring4
    pause delay
    low ring4
    High Ring5
    pause delay
    Low Ring5
    High Ring6
    pause delay
    Low Ring6
    High Ring7
    pause delay
    low Ring7
    next delay
    LOW ARM0
    LOW ARM2
    LOW ARM4
    LOW ARM6
    LOW ARM8
    LOW ARM10
    LOW ARM12
    LOW ARM14
    'EXPANDING RED CIRCLES
     high Arm1
     high Arm3
     high Arm5
     high Arm7
     high Arm9
     high Arm11
     high Arm13
     high Arm15
     High Ring0
    pause delay
    Low ring0
    High Ring1
    pause delay
    Low ring1
    High Ring2
    pause delay
    Low Ring2
    High Ring3
    pause delay
    Low ring3
    High Ring4
    pause delay
    low ring4
    High Ring5
    pause delay
    Low Ring5
    High Ring6
    pause delay
    Low Ring6
    High Ring7
    pause delay
    low Ring7
    next delay
    'EXPANDING MULTICOLOUR CIRCLES
     high Arm0
     high Arm1
     high Arm2
     high Arm3
     high Arm4
     high Arm5
     high Arm6
     high Arm7
     high Arm8
     high Arm9
     high Arm10
     high Arm11
     high Arm12
     high Arm13
     high Arm14
     high Arm15
    High Ring0
    pause delay
    Low ring0
    High Ring1
    pause delay
    Low ring1
    High Ring2
    pause delay
    Low Ring2
    High Ring3
    pause delay
    Low ring3
    High Ring4
    pause delay
    low ring4
    High Ring5
    pause delay
    Low Ring5
    High Ring6
    pause delay
    Low Ring6
    High Ring7
    pause delay
    low Ring7
    next delay
    'EXPANDING WHITE DISC
    low arm1
    low arm3
    low arm5
    low arm7
    low arm9
    low arm11
    low arm13
    low arm15
     high Arm0
     high Arm2
     high Arm4
     high Arm6
     high Arm8
     high Arm10
     high Arm12
     high Arm14
    High Ring0
    pause delay
    High Ring1
    pause delay
    High Ring2
    pause delay
    High Ring3
    pause delay
    High Ring4
    pause delay
    High Ring5
    pause delay
    High Ring6
    pause delay
    High Ring7
    pause delay
    LOW RING0
    LOW RING1
    LOW RING2
    LOW RING3
    LOW RING4
    LOW RING5
    LOW RING6
    LOW RING7
    NEXT DELAY
    'flash all white
    fOR DELAY = 0 TO 100
    high ring0
     high ring1
     high ring2
     high ring3
     high ring4
     high ring5
     high ring6
     high ring7
     PAUSE fastflash
      LOW RING0
    LOW RING1
    LOW RING2
    LOW RING3
    LOW RING4
    LOW RING5
    LOW RING6
    LOW RING7
    PAUSE fastflash
    NEXT DELAY
    'EXPANDING RED DISC
    lOW ARM0
    low arm2
    low arm4
    low arm6
    low arm8
    low arm10
    low arm12
    low arm14
     high Arm1
     high Arm3
     high Arm5
     high Arm7
     high Arm9
     high Arm11
     high Arm13
     high Arm15
    High Ring0
    pause delay
    High Ring1
    pause delay
    High Ring2
    pause delay
    High Ring3
    pause delay
    High Ring4
    pause delay
    High Ring5
    pause delay
    High Ring6
    pause delay
    High Ring7
    pause delay
    LOW RING0
    LOW RING1
    LOW RING2
    LOW RING3
    LOW RING4
    LOW RING5
    LOW RING6
    LOW RING7
    NEXT DELAY
    'FLASH ALL RED
    high ring0
     high ring1
     high ring2
     high ring3
     high ring4
     high ring5
     high ring6
     high ring7
     PAUSE fastflash
      LOW RING0
    LOW RING1
    LOW RING2
    LOW RING3
    LOW RING4
    LOW RING5
    LOW RING6
    LOW RING7
    PAUSE fastflash
    NEXT DELAY
    'EXPANDING MULTICOLOUR DISC
     HIGH ARM0
     high Arm1
     high Arm2
     high Arm3
     high Arm4
     high Arm5
     high Arm6
     high Arm7
     high Arm8
     high Arm9
     high Arm10
     high Arm11
     high Arm12
     high Arm13
     high Arm14
     high Arm15
    High Ring0
    pause delay
    High Ring1
    pause delay
    High Ring2
    pause delay
    High Ring3
    pause delay
    High Ring4
    pause delay
    High Ring5
    pause delay
    High Ring6
    pause delay
    High Ring7
    pause delay
    LOW RING0
    LOW RING1
    LOW RING2
    LOW RING3
    LOW RING4
    LOW RING5
    LOW RING6
    LOW RING7
    NEXT DELAY
    'flashall
     HIGH ARM0
     high Arm1
     high Arm2
     high Arm3
     high Arm4
     high Arm5
     high Arm6
     high Arm7
     high Arm8
     high Arm9
     high Arm10
     high Arm11
     high Arm12
     high Arm13
     high Arm14
     high Arm15
     high ring0
     high ring1
     high ring2
     high ring3
     high ring4
     high ring5
     high ring6
     high ring7
     pAUSE DELAY
    LOW RING0
    LOW RING1
    LOW RING2
    LOW RING3
    LOW RING4
    LOW RING5
    LOW RING6
    LOW RING7
    Pause delay
    next delay
    For delay = 0 to 100
    high ring0
     high ring1
     high ring2
     high ring3
     high ring4
     high ring5
     high ring6
     high ring7
     pause fastflash
     LOW RING0
    LOW RING1
    LOW RING2
    LOW RING3
    LOW RING4
    LOW RING5
    LOW RING6
    LOW RING7
    next delay
     'ROTATE WHITE
    high ring0
     high ring1
     high ring2
     high ring3
     high ring4
     high ring5
     high ring6
     high ring7
     for delay = 400 to 50 step -30
      hIGH arm0
     high arm8
     pause delay
     low arm0
     low arm8
     high arm2
     high arm10
     pause delay
     low arm2
     low arm10
     high arm4
     high arm12
     pause delay
     low arm4
     low arm12
     high arm6
     high arm14
     pause delay
     low arm6
     low arm14
     next delay
     'ROTATE MULTI
    high ring0
     high ring1
     high ring2
     high ring3
     high ring4
     high ring5
     high ring6
     high ring7
     for delay = 300 to 50 step -10
     hIGH arm0
     HIGH ARM15
     HIGH ARM1
     high arm8
     HIGH ARM7
     HIGH ARM9
     pause delay
     low arm0
     low arm8
     LOW ARM7
     LOW ARM15
     high arm2
     high arm10
     HIGH ARM11
     HIGH ARM3
     pause delay
     low arm2
     LOW ARM1
     low arm10
     LOW ARM9
     high arm4
     high arm12
     HIGH ARM5
     HIGH ARM13
     pause delay
     low arm4
     LOW ARM3
     LOW ARM11
     low arm12
     high arm6
     high arm7
     high arm15
     high arm14
     pause delay
     low arm6
     low arm5
     low arm13
     low arm14
     next delay
     goto loop
    The program runs ok until somewher near the end of the @flashall section then instead of going thru the rotate routines it jumps back to the beginning and starts again.
    I would be very happy to post a picture or video clip if someone could point me towards the instructions for doing so which I cant seem to find !
    Thanks all
