How about the PORTA.3 problem Joe mentioned?
This will help
This will help
Go into the data sheet, I know it's painful, but go in there anyway . . . Look to see what state port A initializes in when it is reset, you will probably discover it defaults to <b>Analog</b> operation, since you want Digital, <b> YOU </b> need to tell it<b><font color=red> how to be digital.</font color></b> Lots of registers to set, If you want simple then use old grandpaw chip like 16F84, or 16F628A, only CMCON to worry about. If you want lots of bells and whistles then you have to learn how to play them.
well i have all those pic's you wrote
but i don't want this circuit to work in my lab only
it will work in rough and dirty environment so there is other things must be worried about so the design have more dimension than you imagine
although am not from there but i bet you i worte more code lines than you
wither on asm , C18 , C32 , css , pic basic pro
take this advice
work more ....
and stop been futile person
